First post, by EPoX
old motherboards with massive green battery stuff corrossion even inside and below PCI slots and bellow memory and power connector.
stuff that is not easy to remove, even with a toothbrush and isoprophyl alcohol the stuff is still there and no way to reach below the pci connector.
is there any good way to clean the motherboard for good withot actually havind to desolder the connectors?
even BIAs are suffering since green stuff gets inside and you cant see it in the hole.
small smd capacitors where the soldering just looks rusty and not shiny and solder looks partly eaten
please share experiences.
