Sun-3/260 - SCSI issue
First post, by sorrow
I'm trying to revive an old Sun-3/260. I managed to boot it over network but I'm unable to connect a SCSI disk.
I tried two different SCSI adapters, each being SCSI-3 and each with different cable. I also tried several SCSI disks that were tested as OK on a Sparc or a PC.
I used internal SCSI cable and the bus is terminated on disk. No disk is original SUN-3 but at least one is on the list of known compatible disks.
In all cases kernel panics when it tries to identify the disk. Anybody knows where the problem is?
CASE I.
Boot PROM Selftest
PROM Checksum Test
DVMA Reg Test
Context Reg Test
Segment Map Wr/Rd Test
Segment Map Address Test
Page Map Test
Memory Path Data Test
NXM Bus Error Test
Interrupt Test
TOD Clock Interrupt Test
MMU Access Bit Test
MMU Access/Modify Bit Test
MMU Invalid Page Test
MMU Protected Page Test
ECC Error Tests
Cache Data 3 Pat Test
Cache Tags 3 Pat Test
Memory Size = 0x00000008 Megabytes
Initialization ECC Memory Meg #0x00000008
Memory Test (Testing 0x00000008 MBytes) Testing Meg #00000008
Selftest passed.
Type a character within 10 seconds to enter Menu Tests...
(e for echo mode)
Selftest Completed.
Sun Workstation, Model Sun-3/200 Series.
ROM Rev 2.8.4, 8MB memory installed, Serial #22620.
Ethernet address 8:0:20:6:E3:7.
Diagnostic Auto-boot in progress...ie(0,0,0)
Using IP Address 192.168.50.215 = C0A832D7
Booting from tftp server at 192.168.50.147 = C0A83293
Downloaded 101800 bytes from tftp server.
hostname: 3-160
domainname: darksun.net router=192.168.50.100
server name 'SS5'
root pathname '/export/root/3-160'
root on SS5:/export/root/3-160 fstype nfs
Boot: vmunix
SunOS Release 4.1.1 (GENERIC) #1: Sat Oct 13 06:05:48 PDT 1990
Copyright (c) 1983-1990, Sun Microsystems, Inc.
mem = 8192K (0x800000)
avail mem = 6791168
Ethernet address = 8:0:20:6:e3:7
sc0 at vme24d16 0x200000 vec 0x40
st0 at sc0 slave 32
st1 at sc0 slave 40
sr0 at sc0 slave 48
sd0 at sc0 slave 0
(unknown):
vector 0x8, pc 0xe0aeb34, sr 0x2704, stkfmt 0xb, context 0x0
Bus Error Reg 20<TIMEOUT>
data fault address f002004 faultc 0 faultb 0 dfault 1 rw 1 size 2 fcode 5
KERNEL MODE
page map fb07f900 pmgrp f0
D0-D7 0 2 0 6 f4240 1000 9d 0
A0-A7 e136dd8 f002000 0 e138708 e136dd8 f002000 e0e6748 e0e6734
Begin traceback...fp = e0e6748, sp = e0e6734
Called from e0aeb8c, fp=e0e6760, args=e136dd8 f4240 1000 6
Called from e0ae862, fp=e0e6798, args=e136dd8 37e 80 af
Called from e0af57a, fp=e0e67c8, args=e136dd8 e138708 0 ff0003c
Called from e0af1be, fp=e0e67fc, args=e138708 12 3c 0
Called from e0ae32a, fp=e0e681c, args=e10aa40 e1017e2 20800000 e109f48
Called from e094fe4, fp=e0e6834, args=e10aa40 e155f84 e109f48 e10aa40
Called from e094f0c, fp=e0e685c, args=e10aa40 e109f48 e1017e2 6
Called from e094e10, fp=e0e6874, args=e109f48 e1017e2 9a b0
Called from e094dd0, fp=e0e687c, args=e0e68ac e0977d4 20000000 2e000000
Called from e0977d4, fp=e0e68ac, args=20000000 2e000000 1c0000 fef0098
Called from e027114, fp=e0e68bc, args=ffffffff 4000 0 e0041ae
Called from e0041ae, fp=0, args=ffe9 fef0258 20000000 2e000000
End traceback...
panic: Bus error
rebooting...
CASE II.
Boot PROM Selftest
PROM Checksum Test
DVMA Reg Test
Context Reg Test
Page Map Test
NXM Bus Error Test
Interrupt Test
MMU Access Bit Test
ECC Error Tests
Selftest passed.
(e for echo mode)
Selftest Completed.
hostname: 3-160
server name 'SS5'
Boot: vmunix
avail mem = 6791168
si0 at vme24d16 0x200000 vec 0x40
st0 at si0 slave 32
st1 at si0 slave 40
st2 at si0 slave 24
st3 at si0 slave 16
sr0 at si0 slave 48
sd0 at si0 slave 0
sd1 at si0 slave 1
sd2 at si0 slave 8
sd3 at si0 slave 9
sd4 at si0 slave 16
sd6 at si0 slave 24
(unknown):
vector 0x8, pc 0xe0b71c0, sr 0x2708, stkfmt 0xb, context 0x0
data fault address f002018 faultc 0 faultb 0 dfault 1 rw 1 size 2 fcode 5
KERNEL MODE
D0-D7 2700 2700 37e 80 0 8000 0 0
A0-A7 f002018 e138d50 f002001 e138d50 e137638 f002000 e0e6744 e0e6730
Begin traceback...fp = e0e6744, sp = e0e6730
Called from e0b70ba, fp=e0e6768, args=f002018 8000 0 4
Called from e0b5046, fp=e0e6798, args=e137638 af 38 12
Called from e0af57a, fp=e0e67c8, args=e137638 e138d50 0 ff0003c
Called from e0af1be, fp=e0e67fc, args=e138d50 12 3c 0
Called from e0b45ee, fp=e0e681c, args=e10b2dc e103236 20800000 e10a01c
Called from e094fe4, fp=e0e6834, args=e10b2dc e155f84 e10a01c e10b2dc
Called from e094f0c, fp=e0e685c, args=e10b2dc e10a01c e103236 6
Called from e094e10, fp=e0e6874, args=e10a01c e103236 9a b0
End traceback...
panic: Bus error
rebooting...
Reply 1 of 8, by Horun
What exact SCSI adapter are you trying to and what SCSI HD are you trying to use ?
I know very little about Sun stations and SunOS but am sure you need a Sun3 VME SCSI compliant adapter or it will not work. Do not think any SCSI-3 anything will ever work being the computer is from late 1980's you need a SCSI-I (or early SCSI-2) drive that is less than 528Mb for sure. added: My theory is like you are trying to put a 1540 Adaptec into a 286 with embedded OS from 1990 and expect it to work as-is....
Reply 2 of 8, by megatron-uk
I agree - I think your best chance is to try a 50pin SCSI1 or 2 drive. I've not used anything before a SPARC Station IPC, but the early models did appear to be picky about the drive type.
At the very least try to ensure you have an 8bit narrow SCSI drive, rather than a wide 16bit converted down to 8bit. Yes, most times it should just work, but I've had the odd occasion where the host is clearly not happy about a wide SCSI drive.
https://www.target-earth.net
Reply 3 of 8, by sorrow
Thank you, guys. Here are the additional facts:
The two SCSI adapters are:
Sun P/N: 501-1149 "Sun-2" SCSI host adapter, internal (not SCSI 3, my bad)
Sun P/N: 501-1217 "Sun-3" SCSI host adapter, external
The first one is shown on the attached picture.
The disks used are:
Fujitsu M2624SA - this one was mentioned on some mailing list as compatible
Seagate ST1480N
HP (Quantum) 525MB P/N 0950-2317
DEC RZ25-E
Any ideas?
Reply 4 of 8, by Horun
Not sure if this helps but in the linked Sun-3 Config DOC on page 27 it says "501-1149 Sun VME SCSI Ctlr" is assigned to Slot 7 of the backplane for a Sun 3/260. It also does not show it capable of multiple scsi scontrollers unlike the 180 and 280.
http://www.bitsavers.org/pdf/sun/sun3/Sun-3_C … Guide_Oct86.pdf
If you have not already got them suggest grabbing all the docs here: http://www.bitsavers.org/pdf/sun/sun3/ and in the /3-260/ subfolder
Reply 5 of 8, by sorrow
Thanks Horun.
I have my internal SCSI card in slot 7 - it is the only slot that provides internal SCSI connection. I also tried external SCSI card on slots 10 and 11. But it makes no difference.
I have read the available documentation. The only thing that I cannot find for 100% is how the empty VME positions are to be configured.
Reply 6 of 8, by sorrow
I solved the problem: incorrect pins on empty slots of VME backplane.
Reply 7 of 8, by pentiumspeed
Explain this? Photo would help. Very good detective work.
Cheers,
Great Northern aka Canada.
Reply 8 of 8, by sorrow
The VME bus is configured via jumpers on the VME backplane. In my case it was incorrectly configured. The manual includes configuration instructions but some are not clear.
