Reply 18940 of 31248, by pentiumspeed
imi wrote on 2021-05-08, 23:38:
too bad they're all collecting dust in there and aren't getting used :p no wonder I can't get my hands on an original IBM. […]
vad4r wrote on 2021-05-05, 05:25:
Talked with a friend who also collects...
speaking of IBM
been trying to install Win98 on this NetStation without floppy or CD-rom...
I've been duped into thinking I'd buy a 266MMX with it, seeing as every resource online I found referred to it being specd with a 266MMX, was the reason I got it in the first place, but of course there's only a 233MMX in it 🙁
...rather unsuccessful so far x3... guess I'll have to hook up a CD-rom with external PSU (I don't have the cable that plugs into the MB) after all.
What is this model of this netstation in your picture, is it a pentium class?
Cheers,
Great Northern aka Canada.
Reply 18941 of 31248, by imi
8364-S20
it's a 430TX board with S3 Trio3D and Crystal CS4235 on board with a 233MMX
Reply 18942 of 31248, by wiretap
Installed some 3d printed retention clips to my Amiga 4000 front panel. Epoxied them in place and it works great.
My Github
Circuit Board Repair Manuals
Reply 18943 of 31248, by Caluser2000
Got given this over weight thing with flashing coloured leds of various colors. Ancient, 2011, gaming rig apparently. Core 2 Duo 2.66Ghz cpu or something like that in an ASUS Gigabit mobo, a wopping 2gigs of Corsair ram and humongous 120gig hdd. Has an ASUS GPU with a lot of switches an knobs with fans all over the place.. The PSU is modular ENERMAX and a lot of fun stuff to play with.
The GPU was providing any output initially so I drag a trust y old S3 Virge out of the shed and managed to get in to the bios ok. Fitted a test hdd with a 32-bit Mint Linix Debian Edition ver4 on it to test it out. The original hdd has Win10 on it upgraded from Win7. Couldn't be bothered to wait for Win10 to boot up you see. Everything worked ok. Refitted the gpu a few hours later and it worked fine so I suspect a contact issue after being stored for over 5 years.
I guess hard core gamers would have had wet dreams about owning one of these back in the day 😉
Peace out.
Reply 18944 of 31248, by luckybob
I made a video about a NiB AT computer case, and now i'm going to put parts in it and make a build: Community Socket 7: Choose my parts!
Reply 18946 of 31248, by brostenen
ATX64 progress update.... Out of parts, and need to order more. This is what I have build so far!!!
The attachment ATX64-May-01.jpg is no longer available
The attachment ATX64-May-02.jpg is no longer available
The attachment ATX64-May-03.jpg is no longer available
Reply 18947 of 31248, by Turbo ->
My AT PSU in my 486 PC started making funny noises, so I've replaced it with newer ATX power supply (using ATX to AT power connector). However I forgot something. The ATX PSU has the fan on the opposite side. I've went with the instalation anyway. When testing it, it doesn't seem to be overheating. After an hour or working the fan is only a little bit noisy compared to the noisiness at startup and small amount of warm air is blowing out. I wonder should I keep it like this or should I spit in my hands and empty the case, drill new holes in the back, and cut some metal on the side, to fit it the PSU correct way...
Reply 18948 of 31248, by flupke11
Removed the TUSL2-M with the Tualakin onto a bench as the graphics and SCSI testing platform. I found, whilst looking for other stuff, an old SCSI external cabinet with a Yamaha SCSGI rewriter and this old Quantum UW-disc.
The attachment DSC_3451.JPG is no longer available
At the same time, it was time to check the temperature on that Asus FX5900Ultra. 91° C idle - So I'll botch something together to make another find (old Zalman all copper VGA cooler) fit.
The attachment DSC_3450.JPG is no longer available
Edit: one extra hole in the back heatsink and a few long screws later, I got the temperature down to a proper 50 degrees idle.
The attachment DSC_3453.JPG is no longer available
The attachment DSC_3454.JPG is no longer available
Reply 18949 of 31248, by pan069
Turbo -> wrote on 2021-05-09, 17:35:
I get the DIY ethos, but if you'd ask me, just get a PSU that DOES fit instead of drilling holes in a case that you might regret later...
Reply 18950 of 31248, by PC@LIVE
Today I have prepared a Motherboard for reboot.
It is a TYAN Trinity 100AT (S1590), VIA VT82C598MVP chipset, 1MB L2 cache on board, AMD K6-III 400 CPU (overclock to 450), currently I have 128MB of RAM (PC133 CL3), but it is possible to expand it up to 768MB, yamaha OPL chip ISA sound card (LWHA151A00).
As a video card I have for the moment a 32MB TNT2 AGP, but I had problems with blue screens, so to solve the problem I was suggested to use a different one, for example a GF2MX, it seems that the TNT and W98 and the VIA chipset can create problems (perhaps for drivers).
Another change I will make will be that of the power supply, I will not use the traditional AT, but I will use an ATX, changing the setting of the JP7 jumper, and inserting a button at PIN 1-2 of the J5.
I will also change the HD by putting a 20GB ATA.
This sheet is discussed here:
Tyan S1590 (baby-AT Super7) 3.3v AGP power limits
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 18951 of 31248, by seleryba
Tested a >10 of 386 and 486 motherboards I've bought over the months. 90% of the time was searching for model and manual with jumper settings and configuring itself.
Found out that most of the motherboards are OK. Few of them have broken traces because of the barrel battery - that will be great for some side-projects for someday.
Some highlights from the test run:
The attachment mobo00.jpg is no longer available
The attachment mobo01.jpg is no longer available
Seritech 386AS aka ECS 8517 aka FORCOM M396F. Love that one. It's cacheless but I take it as an advantage. 386SX-33 without any additional waitstates to disable the cache should be perfect for Wing Commander and similar oldies. Also come on, look at that, it's so small and beautiful because of this yellow soldermask. Funny fake "TOSHIBA CHIP6" sticker included - it's just the PC Chips underneath. 😁 Great piece, will do some build with it.
The attachment mobo5.jpg is no longer available
Another cacheless board, this time with 386SX-40. It's awkward that there is 66.66MHz oscillator onboard. Will replace that someday to the 80MHz to fully unlock the CPU power.
The attachment mobo3.jpg is no longer available
Lucky Star LS-486E Rev. D. I definitely like small mobos. It's a complete solution for some last 486 parts. Will be perfect for some AMD 5x86 build.
The attachment hot-403h.jpg is no longer available
Shuttle HOT-403H. Just a nice motherboard filled with Opti chips. Good for ISA-only, pre-72pin system.
Reply 18952 of 31248, by seleryba
Also found two great and working boards with AMI Winbios:
The attachment winbios01.jpg is no longer available
The attachment winbios02.jpg is no longer available
Biostar MB-1433/40/50UIV. Probably same as PCChips M912? Anyway, well-known board with big potential with its VLB slots and a good UMC chipset.
The attachment pcchips.jpg is no longer available
PCChips M919. Geez, I love this one. Just look at this abomination: PCI, VLB, WinBIOS, 256k cache (real one) on COAST module.
The attachment winbios03.jpg is no longer available
I very like WinBIOS by the way, it has some specific vibe of 90s multimedia-screaming PCs.
Reply 18953 of 31248, by creepingnet
Building out a FreeDOS Setup for the Versa M/75. Did a quick run with Win 98 SE and it was just too much B.S. to deal with so I decided "Nah, let's put FreeDOS on that one again" - so it now has 2 HDD - one with Win95 triple boot with 3.11FW and DOS, and then the FreeDOS one which I'll probably be using most of the time.
~The Creeping Network~
Reply 18954 of 31248, by ultra_code
speaking of IBM […]
speaking of IBM
Whenever I install 9x, I copy the contents of the installation CD into a folder on the formatted drive (I call it "win98cd" or whatever, doesn't matter), boot off of a 9x bootdisk, and run
setup.exe /is
in that folder. Works like a charm every time.
Builds
Reply 18955 of 31248, by Jed118
Listed the 486 just now, and spent the early afternoon doing bodywork to a 2005 Mazda 3 which I plan to sell later on.
Next up is the 486 EISA system and the JUKO NEST machine. I kinda hate to get rid of all this vintage stuff, but it's better in someone else's hands than mine, as I won't have the time to devote to it or enjoy it, and when I do, the hardware will likely no longer work 😉
What's for sale? my eBay!
Reply 18956 of 31248, by Jed118
seleryba wrote on 2021-05-09, 22:47:
Also found two great and working boards with AMI Winbios: […]
Duzo polakow tu teraz jest - szkoda ze ceny na Allegro tak skoczyly, ciesze sie ze moglem z tego zkozystac przed "inflacja" 😉
A lot of Poles are here now - it is a pity that the prices on Allegro have jumped so much, I am glad that I could have benefited from it before "inflation";)
Reply 18957 of 31248, by gex85
seleryba wrote on 2021-05-09, 22:32:
... Some highlights from the test run: […]
Hah, I just put together a build with this exact board yesterday. After relocating a Shuttle HOT-541 based Pentium build into a new case, I put the M396F into the one that was now free. I combined it with 8 MB RAM, a Tseng ET4000 graphics card, Sound Blaster 2.0 CT1350B, double speed CD-ROM and a CF card for storage. Fun little system 😀
My retro computers
Reply 18958 of 31248, by seleryba
gex85 wrote on 2021-05-10, 08:50:
Excellent setup. CT1350B with CMS support I suppose?
Reply 18959 of 31248, by gex85
seleryba wrote on 2021-05-10, 09:11:
Unfortunately my card lacks the CMS chips, but I might get the remakes from eBay one day...
My retro computers
