Windows 98SE Boot Disk
First post, by omgfoz
I have tried several boot disk images, copying files on to various floppies, and my system WILL NOT boot from any of it! I keep having errors of all kinds. Even copying files to the floppies is encountering many problems such as errors copying various files. I am about to give up.
Is there a foolproof way to create a Windows 98SE boot disk so I can put a fresh install on a new hard drive? I do not have access to a pre-XP machine from which to do this.
--Rob, Certified AMD Fanboy
Main: Ryzen 7 3700X / Asus Prime X570-p / 32GB DDR4-3600 / Radeon 5700XT / Win 10
Alt 1 (WIP): Athlon Thunderbird 1ghz / Asus A7V / 512MB SDRAM / ATI Radeon 9800 All in Wonder/ Win XP
Reply 1 of 21, by cyclone3d
I use self imaging boot disk images. Even works this way using Windows 10 and a USB floppy drive.
Are you sure the floppy drive and floppy disks are good?
Attached are a couple of the ones I use:
Windows98.zip
815.03 KiB
284 downloads
GPL-2.0-or-later
boot98se.zip
797.45 KiB
398 downloads
GPL-2.0-or-later
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 21, by weedeewee
copying files ?
use something like rawrite or dd to write the whole image onto the floppy
Do not ask Why !
Reply 3 of 21, by Caluser2000
weedeewee wrote on 2021-05-09, 20:54:
copying files ?
What they said ^^^^^^^^
Reply 4 of 21, by omgfoz
I keep getting errors such as what's attached. I want to say I've tried 5 or 6 different diskettes so far. And this happens on my USB floppy drive and an ide drive in my XP system.
    1.94 MiB
Reply 5 of 21, by omgfoz
Well this is the farthest I've gotten so far.. but still got errors.
    1.94 MiB
    517.18 KiB
    759.19 KiB
Reply 6 of 21, by omgfoz
Well... I guess I wasn't patient enough! The eighth(!) disk I tried worked! I guess I have that many bad disks. That's what I get for being cheap and buying used floppies on ebay instead of new old stock. Hey it was 50+ disks for 8 bucks!
    632.76 KiB
Reply 7 of 21, by Repo Man11
Have you considered getting an OEM ISO of Win98 so you can boot from the CD and not bother with the floppy?
Reply 8 of 21, by omgfoz
Repo Man11 wrote on 2021-05-09, 22:19:
If I can't get this install started by this evening I may try that option.
Reply 9 of 21, by omgfoz
I had the setup skip scandisk as the SSD reports free space incorrectly... and now it freezes right at the beginning of setup. Any tips?
    1.6 MiB
Reply 10 of 21, by Jorpho
omgfoz wrote on 2021-05-09, 22:21:
If the computer in question can boot from bootable CDs, then there are any number of ways to make a bootable CD without having the actual OEM ISO.
Reply 11 of 21, by omgfoz
The system us freezing at every step. I really want to install the OS on this SSD but should I give up? I've spent 5 hours on this and just get freezing every time I try something.
Also, it does not show the 90gb partition only the 10gb partition. Any clues why? I partitioned the drive on my windows 10 pc.
    1.44 MiB
Reply 12 of 21, by chinny22
What motherboard are you using and how is the SSD connected?
it could be the motherboard doesn't support large hard drives or IDE/SATA adapter causing issues?
Reply 13 of 21, by omgfoz
I'm using an IDE/SATA adapter. I was able to compete the install using the adapter with a spare 40gb HDD from my old PS3. The motherboard is an Asus A7V which should support the 120gb SSD. Anyway I gave up messing with the SSD for now. The install went perfectly once I swapped to the SATA HDD.
Reply 14 of 21, by RandomStranger
omgfoz wrote on 2021-05-09, 20:48:
Is the motherboard/PC is able to boot from CD?
The OEM Full version is bootable on it's own without floppy.
Reply 15 of 21, by omgfoz
I think the machine cannot boot from CD. I have a copy of 98SE for computers without an OS but it will not boot from it.
Reply 16 of 21, by BLockOUT
when errors appear its probably the floppy drive dead
i was using one last week, it formated a floppy, and when copied an image it failed at 60%
changing the drive fixed it. probably there are capacitors in the drive that are dried up
Reply 17 of 21, by omgfoz
BLockOUT wrote on 2021-05-11, 00:50:
I think the USB floppy drive I use with my windows 10 computer is faulty. Damn cheap Amazon garbage.
