First post, by CJ Grass
- Newbie
I just assembled my retro kit consisting of the PC Chips M321 board with 386 DX40 processor and the SoundBlaster CT3600.
After searching for the best driver for this card, I did everything as recommended, but during diagnostics I have a strange audio dropout when testing 16 bit samples. 8 bit is OK, FM synth and AWE synth OK.
I thought that maybe something is wrong with the card and that I have one more and 100% functional (because it works in a set with a Pentium) I mounted it to 386 and the problem is still the same - the sound is interrupted on a 16 bit test or in games that use 16 bit audio (it's hard to describe, but it's more like interrupting, shutterring... something like this).
Is it a slow processor fault? Does the 386 support SB CT3600?
