First post, by fenderstrat
Hi everyone. I recently acquired a Zida/Tomato 4DPS Version 1.0 socket 3 motherboard. I also got a Am486DX4100 SV8B CPU to go with it. Unfortunately, after several weekends of testing I have not being able to make it work. It does not post, or even beep. The CPU does not seem to get warm at all, even though I took the heatsink+fan off of it.
Here's what I've tried:
First of all, I have been using a buzzer and PC analyzer/POST card for this whole time and I get no codes, only dashes. Voltages are all there though (you can see it in the photos). I have tested this card in other motherboards and the card works fine.
I've tried many different jumper combinations to set the CPU, to no avail. I was not able to find the manual for Ver 1.0 but the manual for Ver 2.1 lists all the same jumpers. I tried pretty much all relevant jumper settings several times with no luck. I found a manual for a motherboard that's pretty much identical to mine (found here: http://www.vogonsdrivers.com/getfile.php?fileid=681 ) and tried those jumper settings, still nothing.
I've tested this same CPU in a different motherboard and it works fine. I've also tried putting an Am586 CPU in the 4DPS, did not work
All this time I made sure that the CPU voltage jumpers were in the 3.3/3.45 V range (so I did not set it to 5V and fry my CPU.... not yet anyway).
I've tested different types of 72 pin RAM, including FPM sticks that worked in other motherboards. Nothing.
Tried removing the cache chips, cleaning them, putting them back. Nothing. Took them all off to see if it would give me a code, nothing.
Tried installing the CMOS 2032 battery to see if it helped. It didn't.
Changed all electrolytic caps (about 13 or so) for new ones. Nothing.
Took the BIOS chip off and tried another chip from a similar (working) motherboard. No change.
I went over the thing with a multi-meter, checking for continuity, and it seems to be OK.
Could not find any obvious physical damage or corrosion anywhere
I'm in the process of testing individual components and reflowing the solder joints, just because I don't know what else to do.
I am waiting to get a Amd DX2-66 5V CPU in the mail, and test that to see if maybe that helps.
Does anyone have any idea of what I might have missed, or anything else I can do?
