First post, by paradigital
- Oldbie
I've recently come into possession of an Asus P3C-E that appears to be stone dead 🙁
Currently loaded up with 256MB of PC800 (2x 128MB sticks), and a P3-733 133FSB Slot-1 CPU. I've tried numerous video cards, but I'm 100% sure that the motherboard itself is the problem.
When powering up the board, my POST test card shows "----" (so totally brain dead). Messing with the CLRRTC or the CMOS battery sometimes make the POST test card show C0--, but more often than not, nada.
I've tried another CPU (P3 500, 100fsb) and as I say, various video cards. Booting without RAM makes no difference to the output. I unfortunately don't have a RIMM terminator to try single sticks, but I'm not sure it would make a difference. The RIMMs are known good.
I've tried both jumper and jumperless configuration for clock speed, as well as "safe" mode and normal mode. FWIW, the board appears to be some kind of OEM version as it has a "VPANEL" header that doesn't show in the Asus manual for the board.
On a wild hunch, I desoldered the BIOS chip and tried to read it with my minipro, but kept getting pin detect errors, so possibly a dead BIOS chip. Replaced with a known good SST 49LF004 and a freshly flashed latest BIOS, the board still shows "----" on the POST test card.
At this point I'm all but resigned to tossing it in the eWaste, but thought I'd throw it out there for anything I may not have thought of.
