First post, by for_coffee
Hi all,
I have a Toshiba 310cdt laptop that isn’t working, it turns on for a second and only when the battery is installed?? Without the battery it shows no sign of life even when plugged in.
Can anyone help me?
Reply 5 of 16, by Zup
I remember having a Fujitsu that did similar things... starting to almost instantly power off, hard disk fails (if it gets that far)... the source of all problems was a depleted CMOS battery.
Maybe you should try:
- Disconnect your HDD.
- Disconnect additional RAM (maybe all SO-DIMMs, I've got a Toshiba that has some RAM soldered in mainboard).
- Disassembly the PC and check CMOS battery voltage.
- Check CPU fan.
- Inspect mainboard thoroughly.
Also, you can find a service manual for your laptop on archive.org. Maybe it can give you hints about how to proceed.
I'm selling some stuff!
Reply 7 of 16, by BitWrangler
Generally just match the volts and the space available. If it's a particularly small or odd shape, give it long leads and find a cell that can tuck away in some other spare corner of the chassis.
Reply 8 of 16, by for_coffee
This is the battery
    970.96 KiB
    1.05 MiB
Reply 10 of 16, by BitWrangler
There's a flat 3 cell pack that comes for cordless landline phones, if you get one of those, cut off one cell at the neg or pos end, you just have to resolder one wire, and shrinkwrap it.
Reply 11 of 16, by keenmaster486
You can buy those CMOS batteries online.
Does the laptop say what voltage it expects on it somewhere?
I think for these Toshibas it should be 15 volts, and CHECK THE POLARITY.
World's foremost 486 enjoyer.
Reply 12 of 16, by britain4
Is it a laptop multi voltage adapter or one of the wall wart type ones?
- P-MMX 200MHZ, PCChips M598LMR, Voodoo
- P-MMX 233MHz, FIC PA2013, S3 ViRGE + Voodoo
- PII 400MHz, MSI MS6119, ATI Rage Pro Turbo + Voodoo2 SLI
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500
- Toshiba Libretto 110CT, 300MHz, 96MB RAM
Reply 13 of 16, by for_coffee
The laptop is a multi voltage charger, here is a photo of it
    1.43 MiB
Reply 14 of 16, by sirotkaslo
for_coffee wrote on 2021-07-06, 09:38:
Without the battery there is no sign of life, the charger has multiple voltage settings. Should I try and up the voltage?
Don't blindly up the voltage. Set it up according to the manufacturer. There should be a label on the bottom side of it. I found this online:
POWER (All models)
Autosensing External AC Adapter 3.93”L x 1.97”W x .98” --- .46 lbs.
Input (Voltage/Frequency) 100-240V; 50-60Hz
Output (Voltage/Amps) 15 VDC; 2A (max)
If this is correct, set it to 15V and no more.
Reply 15 of 16, by Nexxen
I had the same issue a few months ago and just bought a new battery on aliexpress.
Works wonders.
Strange as it should start anyway even with a depleted battery.
Is there a second battery, bigger pack hidden somewhere?
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
