First post, by jheronimus
- Oldbie
Hi, all
I'm trying to add a PCI network card to a system with a Biostar MB-1500PCT motherboard (Socket 5 board with PCI and VLB slots, Opti 546/547 chipset, running Windows 95 RTM. No matter what I do, I get the "Your network adapter is not working properly" error at boot and a yellow mark in Device manager.
I've tried these cards:
- 3COM 3C590 (worked in a similar board with Opti 596/597 chipset even though a common 3C905 didn't)
- 3COM 3C900
- 3COM 3C905
- Intel EtherExpress Pro 100+
I've tried all three PCI slots, I've tried reconfiguring the card with 3COM's config utility and I've also tested PCI support with a videocard.
My full configuration is:
Pentium 100, 32MB of FPM RAM
Tekram DC-680C caching controller (VLB)
Ark Logic ARK1000VL video card (VLB)
PS2 card for ISA (recognised as a serial port by the system, no other serial/LPT ports present in the system)
Sound cards and CD ROM removed to lessen a risk of resource conflict.
Unfortunately, there is no BIOS update, and this particular system works really bad with BIOSes from similar boards.
What could I be missing here?
