HWiNFO for DOS resurrected !
Reply 680 of 944, by SteveC
Mumak wrote on 2021-08-19, 08:38:
I can try that if I get the HWiNFO report + debug file. If there are some markers that could be used, it would be possible.
I had to enable "Skip PnP BIOS Calls" or it froze on the PnP discovery, as well as disable the 'Check Keyboard COntroller and Super IO"
Even with a completely clean boot I get this memory error, followed by the COMMAND.COM Error when running the report. As far as it gets though I've attached the dbg and log.
The attachment 20210823_200401.jpg is no longer available
The attachment 20210823_200408.jpg is no longer available
The attachment HWINFO.zip is no longer available
Reply 681 of 944, by Mumak
Thanks! I will try to add a workaround for the hang during SuperIO detection there. Not sure about the PnP issue yet, might be some problem in BIOS.
Reply 682 of 944, by sprcorreia
I have some issues running HWINFO with my old 486 system. The menu flashes and to read VGA info I have to disable the option to check RAMDAC. VGA card is STB WIND/X with S3 86C911.
Reply 683 of 944, by Mumak
sprcorreia wrote on 2021-08-30, 02:25:
What happens with the RAMDAC option enabled, does the screen become corrupted, crashes or hangs?
Do you know what RAMDAC is on the 911 card?
Reply 684 of 944, by sprcorreia
Mumak wrote on 2021-08-30, 07:37:
Lots of garbage but I can still exit the program.
ADV476KN80E
Reply 685 of 944, by Mumak
sprcorreia wrote on 2021-08-30, 09:41:
ADV476KN80E
Could you please export the VBIOS into a file and post here? You can also use the GETBIOS tool located in this thread. Re: HWiNFO for DOS resurrected !
Reply 686 of 944, by sprcorreia
Mumak wrote on 2021-08-30, 10:43:
ADV476KN80E
From the other post I assume that this is the one needed.
Reply 687 of 944, by Mumak
sprcorreia wrote on 2021-09-05, 13:42:
ADV476KN80E
Yes, that's it, thanks. I will add a workaround for this board to automatically skip DAC test.
Reply 688 of 944, by Martin8bity
Is it China fake or bad detection?
Reply 689 of 944, by Mumak
Are you clocking it at 40 MHz? HWiNFO treats all 40 MHz 386DX as AMD, there were no 40 MHz Intel models.
Reply 691 of 944, by Martin8bity
It is my own build of Groza 386 single board computer http://www.alexandrugroza.ro/microelectronics … sbmc/index.html. The clock is created from 14.31818 MHz crystal by SC425APB and is set to 40 MHz. Thansk for the advice, I will try to lower the clock to 33 MHz.
Reply 692 of 944, by Mumak
Unfortunately I'm not aware of any other way to distinguish an Am386DX from i386DX in software other than the 40 MHz clock. So HWiNFO will always report a 40 MHz 386DX as AMD.
Reply 693 of 944, by Martin8bity
How does it recognize on 33 MHz?
Reply 694 of 944, by Mumak
As i386DX-33.
Reply 695 of 944, by Martin8bity
Oh, I see, so there is no way to distinguish Am386 from i386 on 33 Mhzm, isn't it?
Reply 696 of 944, by Mumak
Martin8bity wrote on 2021-09-09, 13:35:
No, such old CPUs don't have any features that would allow such distinguish.
Reply 697 of 944, by debs3759
Mumak wrote on 2021-09-09, 11:02:
Only way I know to accurately distinguish between an AMD and Intel 386 is with the Universal Chip Analyser, but I'm not sure whether the PGA modules are available yet. Of course, if the chip is not on a motherboard and doesn't have a heatsink glues on, you'd know anyway (if it's not a fake). UCA reads JTAG info.
Reply 698 of 944, by pan069
Martin8bity wrote on 2021-09-09, 10:47:
On that page you link:
support for 80386DX CPUs running at 16 MHz, 25 MHz, 33 MHz, and 40 MHz
Then in the "System Configuration" section:
JP5, JP6, JP7	CPU CLK	80386DX Clock	CL, CL, OP: 16 MHz (**)
CL, OP, OP: 25 MHz
OP, CL, OP: 33 MHz (*)
OP, CL, CL: 40 MHz
Reply 699 of 944, by sprcorreia
@Mumak
The gpu/mem clocks reported are read from the cards or is it some sort of fixed values fom a database?
