Reply 140 of 178, by mkarcher
The STG1702 supports an 16-bit pixel port (on pins P8 to P15), which the AT20C490 does not. As long as you don't select a 16-bit pixel configuration (in software), these pins are not used on the STG1702. The AT20c490 has inputs or voltage supply on all of those pins, so there should be clearly defined levels on all of these pins, and there will be no bus conflicts when swapping those chips. The AT20c490 has RS2 on one of the pins the STG1702 re-purposes for the 16-bit pixel port. This is not an issue because the ARK1000 BIOS access the DAC command register in a way that doesn't require RS2, so installing a DAC without RS2 input on an ARK1000 card will not cause any issues.
