Reply 20 of 22, by Malik
- l33t
1. I just checked the Total Hardware site : That Gigabyte 586ATE does support P200.
(The CPU socket should have the "Socket 7" etched on one of it's borders.)
http://stason.org/TULARC/pc/motherboards/G/GI … -GA-586ATE.html
2. For most of the above games, a P133 - P200 is fine. P75 is ok too for some of them.
3. There's nothing to stop a Voodoo2 running in a low end system. You get clearer throughput-quality.
Just that, "to get the most" out of the Voodoo2 card requires a PII 400 and above to fully appreciate it's potential. SLI setup will help to run in higher resolution. Otherwise, the difference between this and a Voodoo1 is not apparent, other than the video quality in slower machines.
4. Regarding slowing down, have a look at my P133 "experiment" 😁:
The Pentium P54c, the Turbo Buton and the Internal Cache. And Wing Commander I is Happy!
It also has Mau1wurf1977's FSB scaling table. 😀
