elianda wrote:ratco wrote:
You could try using Calmira XP, to get a more modern interface (I find it easier to use than Win 3.1 standard interface).
The machine has 8 MB RAM, I am not sure if Calmira would run so well. With more RAM however I could also run Win95.
I also have the problem with Calmira that it crashes the graphics driver on certain systems (with e.g. TIGA). Since it is no longer in development I doubt this will get fixed.
I would think 8 mbs to be enough to run Calmira XP. BUt not sure, never tried with so little 😀
I never faced that bug either.
It was just a suggestion 😀 I would stay away from windows 95, that was when they really started to blow it up and down xD
Btw, why not use DOS? You can play mpeg videos just fine with that. Though to be fair windows is sometimes more stable with multimedia stuff.
