Reply 20 of 30, by noshutdown
wrote:64MB is way "too much" ram for Win95. Usually the problem with Win9X was disk caching that consumed all the available memory and […]
64MB is way "too much" ram for Win95. Usually the problem with Win9X was disk caching that consumed all the available memory and usually never released it. Windows then used swap file and performance was degraded.
You can use this simple app for limiting cache memory usage:
http://www.outertech.com/en/cacheman-classicor set it manually in System.ini
http://thpc.info/ram/vcache.html
http://thpc.info/ram/vcache95.htmlWith more then 32MB I'd set max cache size around 4-8MB - depend on what apps you're using.
16MB system 2MB
8MB system 1MB
4MB system just 128KB
thanks for your info, i set maxfilecache to 8mb and now my 64mb 486 rig boots win95b with 46mb free, thats 6mb more than before.
however, this means that there are still 18mb used by system(8mb of which being vcache), which sounds not right considering it used to run on 8mb rigs. is there anywhere else that i can shave a few megs off?
