Reply 20 of 22, by SquallStrife
- l33t
As nice as PVMs are (I own more than a few), using the intended display for any system will always be preferable to shoehorning the signal into some other format.
You already acknowledged that it's not running at the intended vertical retrace.
And I sure hope you're not implying that mode 13h isn't progressive on a proper VGA monitor! 😉
