Ok I just tested the PC.
It actually turns on and stays on,  but I get no video
Here, I just made this video: https://youtu.be/S6SOhZIA0BA
And here are some photos of the board with macros on almost every chip I could see:
This is the whole board, "what you see" when you open the PC:
That's the right side of the motherboard, right below the SIMMs; the "Intel" chip I guess is the 386 CPU... soldered in the board instead of being "removable" like my 486.
There's a close-up of the CPU, as you can read it's a 80386SX-16...  it'd be a shame to waste...
I have no idea what goes in this socket, it has always been empty, maybe it's a slot for a second CPU or something, I dunno.
That's the "mod" my father tried to solve the issue, he soldered an AA battery with two wires and plugged it in a CN1 pin-thing... but it didn't solve anything at all.
This is an "ADV476KN66E" chip (I have no idea what it is, actually... I just typed what's written on it 🤣)
I have no idea what this WDC big chip is, might be the "graphics card".
Then there's also this big "EPSON" chip here...
3 SIMMs, that's the maximum this board is capable of... and a perfect healthy cap right in front of them (it's annoying, I always have to bent it to remove and insert the first SIMM, that's stupid)
I have no idea what this is. That marker "4" isn't mine... I don't even write the "4" that way...
The two parts of the board are kept together with these two white things:
Here's the AT PSU's sticker with all of its details:
Here's the back panel, very simple: AC plug, VGA, Keyboard, Mouse, Serial and Parallel
AND YES, IT ACTUALLY HAS A 15-PIN VGA AND NOT 14-PIN LIKE THE 486 !!! Even though it's older... WTF !!!
This is the front panel, in case someone recognizes this PC:
I didn't see the "Dallas RTC" chip anywhere...
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
