386SX wrote:Tetrium wrote:386SX wrote:
Interesting! I never built anything that high level so I always choosed low middle end psu. Actually I've a cheap Corsair VS650 for newer builds and a Enermax EG365 old type for retro builds. The Enermax is great inside with many good components but I don't know about its efficiency.
You learn something new every day! 😀
I don't think it matters much if your rig is under 200W or so when measuring from the wall. Even my Phenom II never seemed to consume that much, but that's also because I stick to mid-range graphics (and I'm not using Seasonic or another absolutely top-brand PSU, I've always gone for the next best thing like FSP) and I'm more of a "playable framerates" guy and don't even have any HD displays here. I actually tend to disable all the extra stuff like smoke because to me that's just an extra annoyance I don't want to have to deal with 😜
I usually buy too the cheap version of a good quality psu. What do you think about FSP psu?
Same here. But I do do my homework before I buy a brand new one. When it comes to second hand, I'll read up if the PSU happens to have any significant design flaws or other quirks I should know about. And the very first thing I do with second hand PSUs is to open them up and have a look inside (and clean it up if it looks ok).
In the old days to me FSP was the easiest PSU to find that wasn't total crap (everyone knew Antec was good, so these were never found for cheaps) and that nobody knew about (everyone wanted Antec and Seasonic so FSP units were kinda forgotten and thus as cheap as the really crappy ones) and the older units (like for instance 300W units with 30A 5v ratings) were pretty good for things like Athlon XP (one of my FSP 300W units powered a Barton for years, though only with a Radeon 9600).
I do noticed that they seemed to start cutting corners a bit after they had already started making 350W PSUs (but mostly with stuff that isn't really super critical), but usually they should never blow up in your face and I'm still never worried whenever I use one (after having taken a look inside that is 😜).
350W FSP powering Q6600 and 8800GTS? Yes it can!
500W FSP powering an AM3 Athlon II quad core + crossfire HD6850? Yes it can!
But I wouldn't really recommend using such configurations for a prolonged period.
I've also had good experiences using other brands that base their units off of FSP designs, like the older OCZ PSUs (actually used 3 of those, each one for a couple years at the least and in different builds) or older AOpen PSUs. I've never had one burn up on me, even though I ended up using FSPs in literally way over half of all my builds (I'm talking about >>20 builds here). The only PSU that gave me problems was some Premier that was lighter than air. Replaced that "300W" sucker with an ancient 235W PSU that knew how to get the job done and all problems went flying away! 😁
I have used many other brands though, but for most of the other brands I ended up using only a single unit (one Antec, one BeQuiet, one Tagan, one Coolermaster, etc) and imo one cannot judge an entire brand that's existed for years by judging a single product.
