Reply 20 of 26, by henryVK
- Member
wrote:And if i connect to the external monitor, same i did on a desktop computer? I ovecome this problem... when i am on a mobility i have some troble (but work) on my home connecting to the crt made this nice and clear or not?
what you think about the soundcard compatibility? and the excessive CPU Speed?
An external monitor should work just fine!
The sound chip is an ESS-Solo1 which should, in theory, be DOS compatible.
Apparently some people have had issues with the PCI cards under Win98:
Assistance needed for ESS Solo-1 DOS support
Re: Problem with ESS Solo-1 DOS Emulation
Graphics chip is a Neomagic 256AV which should be fine.
