Reply 20 of 53, by agent_x007
- Oldbie
Not sure why reading them is that big of a deal ?
The real question should be if it uses them ("Memory" tab from CPU-z), or just reads them (after you pick frequency from EPP) ?
wrote:Dunno what it would do if there was both an EPP and a JEDEC profile for the same frequency.
^I set four basic timings + tRFC + CR + Voltage + Frequency manually.
It does whatever is set in BIOS.
If you didn't set anything on timing side (you left it on AUTO), it always will use JEDEC profile (unless you enable EPP Profile from proper option [example from NV board in my earlier post]).
