Reply 20 of 20, by Grayshazzle
Warlord wrote on 2021-01-07, 20:45:ya well the OP asked about a specific card a geforce 4. Which is known to work on BX boards by everyone. Not about any other card. The issue isn't if it will work, the issue is more does the board good enough to run a geforce 4 because that card use a lot of power. But since its the slower 4200 with less power draw than a 4600TI than it will work just fine.
Thank you, that's the answer I needed 👍
