Need help with old 468
Reply 20 of 44, by weedeewee
Schule04 wrote on 2021-04-22, 21:39:
is it really necessary to seal the traces? Isn't tinning them not enough?
tinning them makes'm thicker and gives'm a coating so the copper doesn't corrode.
sealing the traces makes'm not susceptible to short circuits due to loose screws . 😀
Do not ask Why !
Reply 21 of 44, by majestyk
I would be very careful with sealing. You could regret it, when a second repair is necessary or if components have to be replaced in the future.
Reply 22 of 44, by ThisOldTech
It also depends on how you repair the trace.
If you scrape back some trace that's oxidized from a varta battery leak... and you attach a copper wire along the trace line, you can tin that entire section, but sealing it sure is cleaner and less likely to short.
But yeah, if you tin the entire area, I suppose you don't NEED to seal it. With traces, I'd rather seal them up though. I don't see re-repairing a trace line as much as component replacement. I wouldn't seal component solder points.
I rescue old PCs and keep them from being recycled... and preserve Dos/Win 3.11 Software on https://www.ThisOldTech.ca.
Current Machine: AST Advantage! Adventure 6066d Cyrix DX50, 32M, 500MB, Vibra16 + CD/Floppy
Reply 23 of 44, by gerry
Super Mario wrote on 2021-04-22, 21:01:
If I don't get the motherboard working, can I connect the hard disk to any 486 and access the files, run programs etc on DOS and windows or should I use the exact same motherboard / components?
Main reason why I try to get the PC working is to copy stuff I made in the 90's to my new PC, but I would also like to check windows and run the programs I used back then.
if it's a typical IDE drive and you have another computer that can read it, say an old win 98 or win xp machine with IDE, the you could mount it as a 2nd drive and copy all the files over somewhere safe
Reply 24 of 44, by appiah4
majestyk wrote on 2021-04-23, 05:52:
A bit of acetone on a cotton swab removes the nail polish easily, you can wipe the residue off with IPA..
Reply 25 of 44, by Super Mario
Why is there a sticker on my cpu 😁
Reply 26 of 44, by douglar
Super Mario wrote on 2021-04-23, 10:54:
It’s where I hid the combination to locker #3 at the Newark Greyhound station. 😉
Reply 27 of 44, by Super Mario
What temperature and how long should I bake the motherboard in the oven after cleaning it?
Reply 28 of 44, by megatron-uk
You shouldn't really need to - as long as you get rid of most of the vinegar, then rinsing it off with IPA should mean that the alchohol will evaporate within a few minutes (as long as it isn't dripping wet).
You could use a hair drier if you wanted to speed up the drying, but I don't think it's really necessary.
https://www.target-earth.net
Reply 29 of 44, by Super Mario
The keyboard started working after I soldered L3 and L4 with wires. I got the same errors as before, but not the keyboard error. I pressed F1 to enter setup, but after that the keyboard stopped working. I restarted the computer and got an error "parity error, system halted". I restarted the PC again and now there is no picture on the monitor. The power and turbo lights are off now too.
Reply 30 of 44, by ThisOldTech
Tough to say whether that's a ram issue or just more signs that the contacts aren't clean or the board corrosion needs further attention
Reply 31 of 44, by Super Mario
ThisOldTech wrote on 2021-04-23, 17:56:
I have three sticks, but I'm not sure which way they should be installed. They seem to go in both ways.
Reply 32 of 44, by weedeewee
I'm going to go with, the board corrosion needs further attention. 😀
Do not ask Why !
Reply 33 of 44, by megatron-uk
Super Mario wrote on 2021-04-23, 18:04:
The RAM is almost certainly not the problem - you've still got corrosion on your board and either failed components from the battery leak, or at least one (probably more) traces have been eaten through.
I don't know of any kind of PC memory module that can be inserted fully when flipped 180 degrees. Both 30pin and 72pin modules that 386/486 boards use have notches on one end only, so that the retention mechanism of the socket can only be engaged when the module is inserted correctly.
Reply 34 of 44, by Super Mario
I removed the sound card and one of the memory sticks that looked different and now it works again. I get a message on the startup that I must enter setup. Setup menu, keyboard and mouse all work normally but it looks like that my computer doesn't recognize the hard disk. There's many different options to choose from in the hard disk menu. Automatic detection didn't find it either. The jumper is on the master position. Anyone know how to proceed?
Reply 35 of 44, by ThisOldTech
Super Mario wrote on 2021-04-23, 19:21:
Just going to ask if you've got the hard drive ribbon in the proper position pin 1 on the end where the red line is and the hdd at the end of the two connector hdd cable.
Weird to suggest but sometimes trying cable select (CS) can work on weird drives... is the hard drive spinning up at all? If it's an older drive are there other jumper options to look up or just the CS/SLAVE/Master?
If everything's connected properly and the drive is spinning up, only other option is to try a different drive and try that drive on a different computer... or check your I/O card (if it's not built into the board) to see if the IRQ is set to the proper one for primary IDE...
Reply 36 of 44, by Super Mario
ThisOldTech wrote on 2021-04-23, 20:26:
I added images where you can see how the cable is connected. The hard disk spins normally. Only cs, slave and master. Switching to cs didn't work either.
Mouse is also connected to the same card as the hard disk and the mouse works, so the card should be ok?
How do I check the IRQ?
Reply 37 of 44, by Super Mario
Update. I ran the "detect C" utility in bios again and this time it gave me the properties seen in the image below. I accepted them and after reboot I got an error message "HDD controller failure.
Reply 38 of 44, by appiah4
The values detected by the BIOS are correct, as they are the same as those printed on the hard drive. If at this point you are getting that disk controller failure, either the drive or the controller is faulty IMO. One of them is flaky.
Reply 39 of 44, by Super Mario
I removed the jumper from the hard disk and now both dos and windows work 🙂
Only problem is that the mouse didn't work in dos or windows. If I try to run a program that requires mouse in dos, I get a message "did not find a mouse driver". So I guess I have to install the mouse driver next.
