Reply 20 of 21, by Scythifuge
- Oldbie
It is amazing that with how hazardous using garbage caps in a PC PSU could be, that they were ever used at all by anyone. At any rate, the Delta is installed and the PC is reassembled, and I am back to formatting this pile of floppies. So far, every 5.25 has been a success, with zero bad sectors (including the the one that had bad sectors right before the PSU crashed.) I find that to be amazing. I hope to find a similar deal on 3.5 floppies. The only other issue, floppy-wise, is that the label adhesive is practically nonexistent due to age, so I bought double sided scotch tape.
I bought an adapter with one end having male pins to connect to the front panel usb, and the other end has two usb jacks, with the idea that I can reroute the motherboard USB1/1.1 (not sure what this revision of the P2B has, exactly,) so that once this PC is put where it is going to be, I won't have to deal with pulling it out to attach Sidewinder controllers and other USB peripherals.
Of course I also have to acquire the 2nd Voodoo2, and replace the AWE32 with the AWE64 Legacy, when it is possible to do so.
The only other thing I want to try is rloew's TBPlus package to see if I can put a 1TB in this box, but so far, I can't make heads or tales of rloew's manual and I haven't been able to properly format and set up a drive, hence the slave CF/IDE 3.5 bay drive for swapping 128GB SD cards inside CF/SD adapters. I will try rloew's TRIM program as well, since the master is an SSD on Windows 98.
I want to thank everyone who has posted and offered help, education, and advise. I will eventually make a post about this build - with pics, and will include the desk and the entire set up, as it is a blast from the past and other than the stress - has been a fun project. Of course, I may also ask questions about any other issues that crop up or if I try any esoteric/exotic things with this particular build. I am also getting ready to fire up my Athlon XP build (same idea as the P3 build, including period desk and parts,) which will be connected together with a serial cable with null modem adapter for some fun DOS multiplayer gaming. The P3 desk will also house either a P60 desktop or a 4DPS Tomato 486 (if the board ever arrives from Russia!) and will utilize a KVM.
