Reply 40 of 49, by kenrouholo
- Member
wrote:Get an OEM 250W PSU manufactured by Delta. Most models featured a standard ATX pinout. Not the most power efficient, but built very robustly. Should be reliable, stable, and safe. Also very common and cheap.
You mean one of units with a 12A (or even 16A) 5v rail? Definitely don't do that. Also just a brand name and a power rating is really not enough information to buy a PSU for a specific purpose. They've made lots of different 250w ATX units with varying ratings like almost any other brand. If you know of specific suitable models, model numbers are pretty much required. EDIT to note: I don't mean to sound like I'm questioning Delta as a brand - they're good. Just meant that they have many unsuitable models simply because of the different requirements of modern PCs.
Yes a 750w unit is overkill for total power but total power is not the only rating on such a unit and honestly it's one of the least important ratings to look at. The Enermax EG375P-VE that I keep mentioning has 240w on 3.3v+5v for a 375w unit, which is half the total power but over 50% more 3.3v+5v rail power.
Yes, I always ramble this much.
