Reply 40 of 165, by retardware
- Oldbie
Vipersan wrote on 2021-09-26, 09:34:As mentioned already I have fitted a coin new cell battery holder and diode to replace the leaky varta so it is delivering 3.2 v to the motherboard.
Remember that in the NiCd age, these weren't often discharged below 1.1V/cell, and there was no real incentive to ensure that oscillators continued to oscillate at low voltages and CMOS SRAMs kept their contents below that threshold.
Try again with a 3x1.5V alkaline replacement, or check out whether there is a protective silicium diode on the board (which itself adds another .6V drop). Either shunt it or replace it with a Schottky type.
If the board keeps the memory after that, you know that it needs more than the 3V of a new CR2032.
