Olivetti M20 monitor
Reply 40 of 54, by Bernkastel7734
Well, I had seen a post on vcfed about using an EEPROM as a PROM :
https://forum.vcfed.org/index.php?threads/rep … h-eeprom.64656/
82s181 seems to be drop-in replacement of my MMI 6381 one, and it's just connecting pins, noting much, so the only problem is the code for the EEPROM.
Well, I got some M20s ROM dumps from emulator, they're not labeled, so maybe there is the one I need.
Reply 41 of 54, by weedeewee
mouser & digikey seem to stock that AT28HC64B.
seems like the tl866 programmers can program those.
fyi, digikey also stock the AM27S281APC which looks like a direct replacement, though the tl866 programmer doesn't program it.
options enough , just need the data.
Do not ask Why !
Reply 42 of 54, by Bernkastel7734
I have found one seems-compatible EEPROM in my stock, so we will see, I'll make an adapter for that and see if it's character generator or something else
Reply 43 of 54, by Bernkastel7734
So, I have found that PROM on the M20's schematics. (HW2 page 51) and that's indeed memory mapping PROM, so I have problem now...
    hw2-51.pdf
    125.07 KiB
    24 downloads
Reply 44 of 54, by Bernkastel7734
So I have made an adapter to use EEPROM instead of that PROM and it is not working in the same way it was, so I guess that's good. The problem is that 6381 PROM got 4 Chip select lines, and that eeprom only 1. Got in touch with a person who built a M20 clone, and he said that M20 uses 3 out of 4 CS, and it won't be possible to use some expansion cards with that EEPROM2PROM thing.
Reply 45 of 54, by weedeewee
I saw on vcfed you found the data.
The AM27S281APC is still available on digikey, then you'll just need to find someone who has the equipment to program it.
Do not ask Why !
Reply 46 of 54, by mkarcher
weedeewee wrote on 2022-11-10, 13:17:
I have a Hi-Lo ALL-03 at hand. The documentation says that it supports the AMD 27S280/281/281A. If get an AM27S281A shipped to me, I can program it and send to you. If you live outside Europe, I would appreciate if you support me on the shipping costs. Get in contact with me privately (you should have enough posts for using PMs) if you want to accept that offer.
Reply 47 of 54, by weedeewee
mkarcher wrote on 2022-11-10, 22:41:
mkarcher, You're replying to the wrong person. :-p
oh and bernkastel7734 lists his location as poland.
Bernkastel7734 wrote on 2022-11-10, 13:08:
Bernkastel7734 fyi, I've become uncertain if you need a 27s281 or an 27s280. the difference being the one's output can go Hi-Z. though maybe that doesn't matter.
I should go to sleep. goodnight.
Do not ask Why !
Reply 48 of 54, by Bernkastel7734
Yup, I'm in Poland.
So, M20 works but is very unstable. Sometimes it boots, sometimes it shows RAM Errors.
So, M20 is compatible with MDA monitor, but you need a monitor with VHold and HHold potentiometers.
Reply 49 of 54, by weedeewee
bernkastel7734, what chip did you now use to fix it ?
Do not ask Why !
Reply 52 of 54, by Horun
Wow that is is good that you at least can get it to boot and see the screen. Odd behavior for a UV eprom......
