Thermal compound for retro CPUs
Reply 60 of 81, by tincup
I watched the vids TELVM linked - interesting. Rotating the cpu 90-degrees [in the same direction] every 10 passes seems important - random action grinding will impart a parabolic surface as in grinding a telescope mirror.
Reply 61 of 81, by frisky dingo
There are a few ways to do it, that is just one, Rotating the cpu 45 degrees wile far more tedious does a much better job.
I do 100 passes then rotate 90 degrees.
Reply 62 of 81, by RDRAM
It's just my personal taste
Almost all kind of compound last 2-3 years, then they do transfer little heat (dry up).
When I build a machine i want it to last for a least a decade without disarm it (exept blowing dust) so what i do is a homemade old school heatsink lapping to mirrow level and a very smooth laping to ICs (lightly) and no compound at all, and i test they got pretty warm, so they're doind the job.
Reply 63 of 81, by appleiiguy
I use Icefusion on all my pre P4 machines and NT-H1 on the newer stuff. I also use the Icefusion on the GPU heatsinks, last week I pulled the heatsink off a MX 400 and the paste was dry caked dust.
Reply 64 of 81, by TELVM
RDRAM wrote:
... what i do is a homemade old school heatsink lapping to mirrow level and a very smooth laping to ICs (lightly) and no compound at all, and i test they got pretty warm, so they're doind the job.
For peace of mind I always drop a very small drop of thermal paste after lapping.
But superb metal to metal surfacing can achieve surprising results 😲 : https://www.youtube.com/watch?v=fnoVV-RWIWY&t=11m36s
Let the air flow!
Reply 65 of 81, by Dreamer_of_the_past
I would love to try one of those Shin-Etsu Japanese thermal pastes. It might be the best thermal paste money can buy. Although it's probably not worth using on retro stuff.
Reply 68 of 81, by frisky dingo
swaaye wrote:
frisky dingo wrote:
Has anyone ever solder a heatsink to a cpu?
How about liquid metal TIM? Do you even need to worry about surface flaws then?
I tried that stuff before. It's nice, but you have to be careful with it.
Reply 69 of 81, by tincup
Does anyone know how the cpu internals are connected to the cpu heat sink itself? is the chip 'fused' into the metal sink during manufacture or does it employ some kind of mechanical connection perhaps not unlike how the cpu is secured to the HSF, only permanently?
Reply 73 of 81, by Snayperskaya
I've used the white, generic stuff for a long time. Switched to Thermaltake TG-1 after I saw the breakage of oils and solids (hard crust on the middle, gel-like substance on the borders of the heatsink) while cleaning a CPU. Nowadays I use MX-2 and MX-4. Nice temps and not hard to apply correctly. Also not electric conductive, so it's safe to be used even on exposed dies.
Reply 74 of 81, by TELVM
Yep if we remove the IHS to clean the old paste, apply fresh one and then put the IHS back, it makes sense to clean and lightly sand the underside of the heat spreader while we're at it.
No need to lap the die, they come already well flat and polished and any lapping would probably destroy it.
Let the air flow!
Reply 75 of 81, by candle_86
if you take the IHS off, might as well leave it off, unless your going to scrape off all the old epoxy so the IHS sits 100% against the die again for sure. Its pefectly safe to not use the IHS, we didn't have them on P3's, Athlon's or Athlon XP's remember.
Reply 76 of 81, by Kodai
That was fine with the older sockets as the had some wiggle room that could help preventing cracking the core from to much pressure. Mainly because they had clip on posts that were much closer together as the CPU package was smaller. Cracking the core still happened but only to overzealous handling of the cooler or from people who had never installed one before. Nowadays we use the motherboard to get extra leverage over a much larger area than the old socket system and its designed with the IHS in mind. If its removed, then shimms will be needed or the chance to crack the core will be sky high.
Reply 78 of 81, by candle_86
last chip I delidded was an i5 2500k and then i put my hyper212+ back on it without an issue, no cracked core at all.
Reply 79 of 81, by Kodai
I didn't say/imply that it would crack it every time. I pointed out that times have changed and the risk is far greater than it used to be because the current mounting methods require far greater force. Going off the top of my head, the amount of force used for old athlons and P3's was somewhere between 15-20 ft lbs. Now days its double that. Adding shimms help aid block/heatsink installation by preventing some of that force from going in the wrong direction if you manage to slip a few degrees when pushing down. It not at all hard to put a wee bit of pressure on one corner when pushing down and crack a core of a de-lided CPU. Just because you managed to do once doesn't mean you can do it again and again without any risk. Lots and lots of people started breaking their later gen athlons when the coolers and sockets got bigger. Many others managed to install the cooler but missed good contact with the core and fried the CPU. That's why AMD started putting IHS's back on their trayed CPU's.
