First post, by xtreger
Hope you're all doing well. I've seen motherboards with dual PCIe x16 slots, but with a caveat that one is a primary slot that runs in full x16 mode, while the other runs at x8 mode max. Do there exist any motherboards that have two PCIe x16 slots that can simultaneously run in full x16 modes if GPUs are put in them?
I'm talking about GEN 1 PCI x16 slots btw, to be used for retro GPUs (like up to GF 7800 GTX)
Also, does a GPU in a PCI x16 slot running in x8 (or x4) mode mean that it'll give drastically reduced FPS in games? Thanks!
Reply 1 of 5, by DosFreak
For multiple x16 pcie you'll need threadripper or equivalent.
Real world for gaming in even the latest gpus x16 isn't needed, x8 is fine.
Make your games work offline
Reply 2 of 5, by nhattu1986
I think the nvidia 690 and 790 chipset that support SLI it does have 32 lane of pcie which can provide two full size x16 slot for SLI support.
https://www.anandtech.com/show/2482/2
If you want to play with SLI then the nforce board should be the safe choice although they tend to dying due to chipset heat.
for intel, there are x38/x48 chipset that have 32 lane pcie which also provide 2 x16 slot with full bandwidth but they mostly support crossfire.
for amd, according to wiki, they have crossfire express 3200 with dual x16 support, the 790FX, 890FX, 990FX with dual x16 slot or quad x16 slot with x8 bandwidth
Reply 3 of 5, by Standard Def Steve
If you really want to go back in time and grab a period-correct board, the Asus A8N32-SLI Deluxe will do that for you. That's a socket 939 nForce 4 SLI x16 board.
Also, any reputable X79 board will do that; SB-E and IVB-E CPUs provide 40 PCIe lanes.
Reply 4 of 5, by pixel_workbench
X58 chipset boards on lga1366 also usually have 2 pcie x16 slots. And they support sli and crossfire.
As for running in pcie x8 mode, the performance difference is typically negligible. That's if using the same generation slot and gpu (ex: pcie 1.0 gpu on pcie 1.0 slot).
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 5 of 5, by BitWrangler
A 7800GTX is barely gonna notice running on 4x vs 16.
There were some tests recently where 3060 was just barely slower on 8x. So yeah, nice quest and all, but it's a bit like looking for an ATA133 interface for your 386.
