First post, by Tomek TRV
I am trying to repair FIC KC19+motherboards ( https://theretroweb.com/motherboards/s/fic-kc19-hp-oem ). Some stupid guy ripped out the transistors which are mounted between paralell port and slot 1 (these with radiators) and also smached some surface mounted elements. I have 3 of these boards so I found the parameters of surface mounted capacitors and resistors but I need informations about the type of transistors Q4 and Q5.
I have also FIC VB-609 ( https://theretroweb.com/motherboards/s/fic-vb-609-oem ) with FDP7030L and IRL3103 transistors. This part of motherboard where they are mounted looks similar to KC19+. If I will not get any informations which type of transistors were mounted on KC19+ I will use these from VB-609. I know that it is not a good idea but what else can I do?
Please help me to restore FIC KC19+ motherboards. They are interesting for me because they are using RAMBUS memory which is not so common on slot 1 motherboards.
Reply 2 of 6, by dominusprog
Take the transistors from FIC VB-609, it should be okay.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 4 of 6, by PcBytes
From the TRW photo, I can confirm that one of the transistors is a FDP7030L, so the parts are likely same as VB-601.
Reply 5 of 6, by Tomek TRV
As I wrote in my second post that I used transistors from FIC VB-609 and KC19+ is working fine. Thank You for Your answers. It is a pity that they appeared when I lost all hope and tested this solution with transistors from other board but I really thank You for Your answers. Now I have to try with two IRL3103 because these transistors from VB-609 were just for test, I want to have all boards functional. FDP 7030L is impossible to buy in my country so maybe somebody knows what can I use instead.
Reply 6 of 6, by PcBytes
I figure this should help you:
https://alltransistors.com/mosfet/crsearch.ph … s=TO220AB&cf=on
It usually shows you the equivalent transistors that you can use in place of a FDP7030L. Personal choices would be IRFP3713 and FDP6670AL.
