First post, by LequaRex
First off all, I tested the module and DOS won't boot. I took it out and when I looked at it, I saw, that the resistor network RN16 was in half (this module was purchased as USED on eBay [no defects listed]). I desoldered it and part of the circuit wire came with it... I'm pretty sure I can bridge that tho. It had a 220 on it (I assume that means 220 Ohms?). It looked the same like those four others you can see on the bottom of the module.
Reply 2 of 2, by LequaRex
I'm thinking about upgrading it, because there are two empty 32Kx36 labeled spaces and there are two solder places for resistors, labeled with 512K and 256K.
Idk if those will do the job?
https://www.mouser.com/ProductDetail/Texas-In … %2FIEgBpoqx0%3D
