First post, by AngelaTheSephira
As the title says. It doesn't seem to be online anymore. Does anyone know of a mirror of it?
HP OmniBook 600CT
i486/DX4-75 | 16 MB RAM
800x600 full-colour LCD
256 MB CF card in a PCMCIA adapter
Reply 2 of 27, by AngelaTheSephira
Yeah, for me it times out after 15 to 45 seconds:
    6.62 KiB
HP OmniBook 600CT
Reply 3 of 27, by Joseph_Joestar
Modern browsers block FTP access by default.
Try using a dedicated FTP client like FileZilla.
Reply 4 of 27, by darry
AngelaTheSephira wrote on 2024-05-14, 05:30:
I would guess that it's either an issue with the peering link your ISP is trying to use or maybe the ftp server's host is blocking an IP range that happens to include your current IP address (i.e. someone with an address in that range did something the hosting service didn't like so they blackholed the entire range).
https://www.isitdownrightnow.com/ftp.spez.com.ua.html
Reply 5 of 27, by darry
Joseph_Joestar wrote on 2024-05-14, 05:35:
Good point, but If the client application being used works with other FTP sites, it's likely not that.
+1 to FileZilla either way.
Reply 6 of 27, by konc
Something is definitely not OK with this ftp, browsing is OK but downloading happens at dial-up speed with constant failures after aprox. 1'.
@AngelaTheSephira if you only want a specific file, try some client that will automatically reconnect and resume.
Reply 7 of 27, by darry
konc wrote on 2024-05-14, 05:47:
It's not fast, but it is working for me .
8.2 KiB
No downloads
Reply 8 of 27, by AngelaTheSephira
Windows File Manager on Windows 10 blocks FTP even though it has a client for it?
As far as the others have said, I'll try FileZilla but it didn't work last time I tried this about two years ago either.
HP OmniBook 600CT
Reply 9 of 27, by AngelaTheSephira
AngelaTheSephira wrote on 2024-05-14, 20:23:
Never mind, Dolphin seems to be fine with it. I wonder if my ISP is blocking it themselves.
HP OmniBook 600CT
Reply 10 of 27, by BitWrangler
Cool, authentically retro 🤣 ... but seriously that used to happen all the time when ftp sites had too many connections, even on a university T1 line your downloads would be ticking over at 4-5kB per second.
Reply 11 of 27, by AngelaTheSephira
BitWrangler wrote on 2024-05-14, 20:27:
I'm probably going to mirror it so people like me can actually make use of it. I'll let you guys know when it's mirrored, but given the immense speeds of a whopping 9 KiB/s/file, it will probably be a LONG time. Should I mirror the BBS folder too, or is there big legal trouble with that one? I doubt anyone would complain about drivers, but I'm not sure what all is in the BBS folder.
EDIT: Spelling
HP OmniBook 600CT
Reply 12 of 27, by AngelaTheSephira
AngelaTheSephira wrote on 2024-05-14, 20:25:
I have just installed FileZilla on my home server and accessed it using SSH X11 forwarding:
On the home internet, the server is completely nonresponsive. On my hotspot in my car, it's fine.
For some reason, my ISP is blocking that IP. I wonder why, or if they even know it's being blocked.
HP OmniBook 600CT
Reply 13 of 27, by konc
AngelaTheSephira wrote on 2024-05-14, 21:38:
If you are behind a Carrier-Grade NAT some simple implementations (without ALG) break, among other, the FTP protocol. I wouldn't expect an ISP using such a thing nowadays but who knows... Can you connect to other FTPs?
Reply 14 of 27, by Deunan
Depending where you live this might be more of a political issue than technical one. Food for thought.
Reply 15 of 27, by infania
Hey. We have a mirror of that FTP
Its syncing right now, so it is finished in a hour
https://ftpmirror.infania.net/sites/ftp.spez.com.ua/
Swedish computer hoarder
http://www.infania.net/
http://th99.infania.net/
http://ps2.infania.net/
Reply 16 of 27, by Roman555
infania wrote on 2024-05-15, 11:45:
Cool!
It was a pain to download from there as their ftp allows downloading only one file at once (IIRC).
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 17 of 27, by debs3759
I'm getting 3 files at once, mostly at 9.8KB/s.Any more than that and I get frequent errors. Have removed about 1 GB from the queue that I view as irrelevant or large files I have elsewhere (I need a 12 TB drive for my mirrors!)
Reply 18 of 27, by AngelaTheSephira
konc wrote on 2024-05-15, 06:51:
My hotspot is a CG-NAT, but my home Internet isn't.
HP OmniBook 600CT
Reply 19 of 27, by AngelaTheSephira
Deunan wrote on 2024-05-15, 11:06:
Nah, I can access both Russian and Ukranian sites just fine. Unless the FTP server itself is blocking it...
HP OmniBook 600CT
