First post, by Nunoalex
Hi good folks !
Another noob question of this retro enthusiast....
I have several AT cases that have damaged or missing clunky power switches and I cannot find the correct ones online to order
Does anyone know the correct reference or online store that (still) sell this switches ?
I want to sell a few cases but I want them to go in perfect working order.
I have ordered once a few of these but the distance between screw holes were wider and cannot use them
I know that probably there are many variants, I even have cases that the button attaches to a plastic piece and then to the metal case.
But the one I'm looking for is the more common, standard one that screws directly to the metal case
thank you!
    48.54 KiB
Reply 3 of 8, by Nunoalex
kingcake wrote on 2024-05-15, 21:52:
That last time I needed one I just got it off eBay. Tons of new ones on there of all different shapes/mounting.
ebay is a trash site
It is impossible to search anything there without being bombarded with millions of OFF topic search results
If I write "at power push button" I get 7000 results for dental cleaning tools
I have quit ebay more than 10 years ago
I was more interested to know where retro enthusiasts might point out, like an online shop... digikey... mauser... that kind of electronics shops
thanx
Reply 4 of 8, by kingcake
Nunoalex wrote on 2024-05-15, 22:43:
ebay is a trash site It is impossible to search anything there without being bombarded with millions of OFF topic search results […]
thanx
Are you a non-english speaker? It's called a switch. Not a push button.
Reply 5 of 8, by TheMobRules
Just get it from eBay, I did a simple search and found several listings... try "computer power switch" or something, you will find one of those quickly. I doubt Digi-Key and Mouser sell those types of switches anymore, and if they do it will probably be more expensive.
Reply 7 of 8, by Namrok
I think I used a KDC-A10 for one of mine. Although that was with an ATX power supply using an AT adapter.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 8 of 8, by Nunoalex
kingcake wrote on 2024-05-16, 00:09:
thanx
Yes I am not a native but that is not the point
I have seen "power button" "on/off switch" "push button" etc etc I dont know how to do a proper search... I thought there was a standard part numeber for this kind of stuff..
Anyway thank you for the help.. I have found several adds on aliexpress .. now I only need to measure the "switch" physical characteristics to make sure I get the right part because there are millions of different switches
https://www.aliexpress.com/item/1005004678830 … 7Cquery_from%3A
And YES, looks like the part number for this kind of AT power swith is in the ball park of "KDC-A04"
