Reply 46540 of 49486, by weedeewee
OMORES wrote on 2022-10-03, 17:15:
This Audiodrive ES-688, with many IDE connectors..
FYI, there might be one IDE connector, the others are mitsumi/Sony/Panasonic CDROM connectors.
Do not ask Why !
Reply 46541 of 49486, by Shponglefan
I recently bought an Apple IIe via ebay. I'd hesitated buying online due to the prospect of shipping damage. In this case, the seller was only two hours away, so I offered to pick up instead of having it shipped. Frustratingly they responded that they don't do pick ups and that they had shipped out claiming it was "well packaged".
When the computer arrived my fears were confirmed: the outer case had been cracked and broken during shipment.
The monitor itself is still enroute and I have to wait to see if that survived or if it also suffered damage.
Very frustrating that a two hour drive would have prevented damage to this machine if the seller had only been willing to let me pick this thing up. 🙁
    458.88 KiB
    408.66 KiB
Tandy 1000 TL build
286 Epson build
Ultimate Windows XP build
Reply 46542 of 49486, by dormcat
weedeewee wrote on 2022-10-03, 18:12:
The left end of the photo is rather fuzzy, but one can still read those captions on PCB from top to bottom: Mitsumi, Sony, Panasonic, IDE.
Reply 46543 of 49486, by SteveC
Shponglefan wrote on 2022-10-03, 19:34:
I recently bought an Apple IIe via ebay. I'd hesitated buying online due to the prospect of shipping damage. In this case, the s […]
Ah that's real sad 🙁 What will you do? Get some sort of refund?
Reply 46544 of 49486, by pete8475
Seeing those pics is really frustrating.
I bet they insisted it'll be well packed too.
Argh.
Reply 46545 of 49486, by Shponglefan
SteveC wrote on 2022-10-03, 23:14:
I'm going to wait and see what happens with the monitor (if and when it shows up), then we'll see.
If the monitor arrives intact at least I may have reason to keep things, albeit I will push for either a partial refund or see if they can supply a replacement case.
But if the monitor is also damaged, then I'll push for a full refund.
Tandy 1000 TL build
286 Epson build
Reply 46546 of 49486, by Shponglefan
pete8475 wrote on 2022-10-03, 23:35:
They did. When I initially told them I wanted to do a pickup, they said they've sent other machines much further with no damage and not to worry.
And in fairness, the packing wasn't terrible. If it had been a normal PC case, it probably would have been fine.
But for something this old and with brittle plastic it really needed to be properly double boxed.
Tandy 1000 TL build
286 Epson build
Reply 46547 of 49486, by bjwil1991
The other day, I bought a DataExpert EXP8551 ver 1.2 and a replacement Dallas RTC since the original might be flat.
420.75 KiB
The board was sold as-is for parts/repairs and I got the board and replacement Dallas RTC today and I got some components out to give this a good testing. I just need to take the 386 board out of the PCS case and place the Pentium board in the case.
Reply 46549 of 49486, by Veeb0rg
bjwil1991 wrote on 2022-10-04, 01:17:
I thought about buying that board just for the white ISA slots.
Reply 46550 of 49486, by Nexxen
If you want to vent,
Received these (destroyed) hardware today - Shipping gone wrong, our stories.
I understand your frustration 100%
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 46551 of 49486, by PcBytes
Scored this nice Medion/MSI Geforce 4 Ti4200 AGP8x. Needs some cleaning and a bit of bicycle oil on the fan's bearings, but I have high hopes in getting it to work fine. 40ns memory, btw.
Any tips for the GF4 Ti4200? Anything I should be aware of in particular?
Reply 46552 of 49486, by BitWrangler
PcBytes wrote on 2022-10-04, 12:03:
Don't look up pencil mods, or you'll waste a year trying to get a 20,000 score on 3DMark2001SE... be happy with 19,450.... (Normal at stock clocks is more like 8-10k btw depending on CPU) No particular gotchas though, 4200 is a stout card, caps might be getting tired by now, but that goes for everything 10+ years old.
Reply 46553 of 49486, by PcBytes
I was sane enough to not try any pencil mods on Athlon XPs, so I'm good on that regard 😀
Reply 46554 of 49486, by Meatball
Found and bought this Voodoo4 4500 listed as a Voodoo3 2000.
***->WINNER, 1ST PLACE<-***
2022 #QUAKE3totheMAX -560.5fps-
Brain Drain Retro LAN https://discord.com/channels/799008837918261328
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
DDR@411MHz (2-3-3-3)
GeForce 256 DDR@144/344MHz
ESS Maestr0-1
Reply 46557 of 49486, by Radical Vision
Meatball wrote on 2022-10-04, 14:25:
Nice found for sure.. Let me guess u did pay very good price of like 100-130$ since was listed as Voodoo III 2K.. Voodoo IV 4.5K usually sells for like 300-400$ i think..
stef80 wrote on 2022-10-04, 14:40:
Two notches on AGP connector are dead giveaway. Was this the only Voodoo with AGP 4x compatibility? (at least physical)
Nah there was Voodoo 5 5000 that had also universal AGP slot.. There are some indications of some rare V5 5500 with also universal AGP slot... But is whatever since many boards of that time period 1999-2000-2001 did have on them Universal AGP slot so in the end does not matter at all...
    1.25 MiB
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 46558 of 49486, by Meatball
Radical Vision wrote on 2022-10-04, 15:48:
Yes; something like that, heh.
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
ESS Maestr0-1
