Reply 47840 of 57170, by bestemor
- Oldbie
BitWrangler wrote on 2023-01-31, 03:08:Yes, outgoing memory tech gets a dead cat bounce as availability dries up while systems maxed out are still useful. DDR3 appears to be near the bottom of the curve at the moment, but in a year or two will go spendy for a while again, so stock up if you think you'll need it.
+1
