Reply 48920 of 57151, by pentiumspeed
Offered and bought a used Automatic Seiko from USA because I had to replace my current Seiko automatic watch had incorrectly serviced using thin crystal (sapphire I think) finally shattered, should had been a thicker type but the crystals I see out there even correct one are heavily beveled than originals. Repair watch forums had same comments about these issue.
This watch is much treasured because this is hard to find this particular dial style but I fortunately found another with same face style. Easy to read even in the dark.
I'll rehouse my other watch in another case with good crystal once I found another one. Seiko is smart about keeping movements the same dimensions, eg: I can swap ancient 1960 era 17 jewel 6308 movement for new modern Seiko Sii 24 jewel NH35A movement and keep original hands and dial.
BTW the india sourced seikos are 100% fakes (including case) even the movements are sloppily serviced or worn out, even rusted (!!), I did source an couple for curiosity sake. Not of correct dimensions vs original Seiko design.
Cheers,
Great Northern aka Canada.
