Reply 51600 of 53057, by Trashbytes
- Oldbie
PcBytes wrote on 2024-01-28, 10:29:I'd replace the CPU caps at least, if RTC mod fails to POST. I've seen quite a lot of those 1990s caps fail without any bulge. (yes, I'm looking at ya, Jackcon and ABIT.)
Ill keep that in mind once I get the board, going to give it a thorough going over before even powering it up, might even remove a few VRM caps and check them for tolerances, I have a post card handy too.
I wonder what Pentium IIs it supports, Im thinking the early Klamath would be the best bet, say a 233 or 266. Gigabyte lists it as supporting 233 - 300 so early Klamath is correct.
-Just realised I may not actually own a Klamath ...most of the PIIs I have are 350+
