Reply 51900 of 57128, by Kahenraz
- l33t
There is nothing wrong with a good 4:3 LCD. Dell made good panels for the time and, while they may appear a little dull compared to modern IPS panels, they are good workhorses. I keep a matched pair of small 15" Dell panels specifically for retro machines.
Those Dell Optiplexes are also good all around socket 775 Pentiun and Core 2 machines, although nothing particularly special. I believe those models are all 1x PCIe x16 and 3x PCI or 2x PCI and 1x PCI x1 (none have AGP). The power supplies are somewhat anemic and don't have dedicated PCIe power cables for graphics cards, at least not on any of the SFF ones that I've seen, and I expect the desktop power supplies to be very similar.
Any of those as a kit would make a fine no-frills Windows XP machine.
Also of note is that the motherboards are all non-standard and use headers specifically designed for those cases. So don't expect any of them to be useful as parts. Even if the ATX power connector is standard, the power supply mounts may not be. Again, I've only observed the SFF Optiplex machines from that era, but I wouldn't be surprised if the power supply in the pedestal tower does not provide mounting holes for a standard power supply.
CPU upgrades also need to be planned very carefully, as the heatsinks are often monolithic slabs of aluminum with ductwork and screw mounts that may not take a standard heatsink. So if you do plan to upgrade, it is best to stay within the same TDP envelope.
In an effort to thin out my collection, I have been exploring these old Optiplex SFF machines exclusively for a range of Windows XP era gaming, as they take up half as much space as a full system. They are excellent, but with caveats (several of which I mentioned). As long as your use case is narrow enough, they may be perfect. I find them to be particularly handsome, so I am definitely bias.
Here is a picture of the inside of one an Optiplex 580 where I've been testing and labeling compatible CPUs.
