Reply 51940 of 52951, by BitWrangler
- l33t++
rkurbatov wrote on 2024-02-25, 22:07:I don't know why, but I bought that strange 486 early board with ISA ports only. Soyo SY 020C. And 486 DX-50 in pair to it. […]
Typical 486 is DX2-66 with VLB - that is quite interesting per se, but it's PC of year 1994, that transition between Win3.11 and Win95.
But finding something of the early high end is somewhat problematic - components are much more rare and expensive (were and are).
It could be pretty interesting build - I have ATI Mach 32. If it really has Bus mouse onboard , then I need Microsoft Bus-mouse.
Probably one of my 2.88 floppy drives can be an interesting match. And if I had Adlib Gold - it would be something really special - full of strange and expensive components that never became popular and quickly became obsolete.
Logitech bus mouse should also work. If you see Microsoft "kidney" mouse with a serial connector, check the label underneath it might be serial and busmouse, just needs an adaptor. Think it was "in port mouse" they called it.
Edit: Just thinking, mine has a sage green color plug, don't know if that's helpful for quick ID.
I have an old CAD system, has Asus ISA-486 motherboard and Diamond Stealth VRAM ISA, it only had a DX33, but I am thinking of putting my DX50 in it.
