Reply 200 of 52977, by Amigaz
- Oldbie
Onboxed:
The beast:
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Onboxed:
The beast:
Nice.
I am tempted to upgrade my PPro 200 with one of those (the 440FX DEC motherboard has solder pads for a second ZIF socket, but only one fitted - I guess it was a at-purchase option)..... but I don't know if I can justify the cost (as you no doubt know they're rather expensive!) when I've got a perfectly good slot-1 440BX board if I want something a little quicker.
https://www.target-earth.net
thanks for the photos amigo, I did not remember/knew this overdrive... bench it and report 😁
wrote:thanks for the photos amigo, I did not remember/knew this overdrive... bench it and report 😁
Which type of benchmark you want me to do?
The machine has a Matrox Mystique + Voodoo 1
Win98SE + Win NT4 server is installed
I was thinking one similar to a "normal" slot1 pII... but a "before" and "after" becnh could work too 😁
I am just curious how this overdrive scored in terms of performance
wrote:I was thinking one similar to a "normal" slot1 pII... but a "before" and "after" becnh could work too 😁
I'll think of some good windoze benchmark to run 😉
Maybe a Quake II bench or something...or Winstone benchmark
I think 3dmark would be a waste because of the slow Voodoo 1
Quite curious too what the difference will be
Bah, the Overdrive cpu's don't work in my Micronics W6LI mobo...
The post as 266mhz cpu's but can't get past POST
wrote:dang 🙁
Going to test it on my Asus dual P Pro rig when I have time, that board isn't so...."obscure" 😀
Another "stick-only" Thrustmaster F-16 FLCS has arrived.
@Kreshna Aryaguna Nurzaman
Damn...why didn't they make cool joysticks for us "lefties" too? 😢
wrote:@Kreshna Aryaguna Nurzaman
You're left-handed? Wait, I believe there is a good left-handed (or universal-handed) joystick out there. IIRC it is Saitek Cyborg or such.
As for throttle, you can actually use left-handed throttle (throttle for right-handed people) in your right hand, but you will need to reverse throttle in order to press the throttle buttons with your thumbs.
Or, you can use "symmetrical" throttle like Thrustmaster WCS.
wrote:
I notice the second adapter has the other type of plug. I'm guessing it connects to the mother board without use of the ribbon cable. Have you tried using both of them together?
wrote:wrote:I notice the second adapter has the other type of plug. I'm guessing it connects to the mother board without use of the ribbon cable. Have you tried using both of them together?
The second adapter is a dual adapter and I often use two CF cards in that one...
Haven't installed that rear bracket one, as my case is always open and pulling out the CF card is very easy.
Here is a pic with only one CF card loaded:
The reason I ask is that I see it has a jumper for Master/Slave. Why would it have this if it weren't meant to be able to have two adapters on one bus? But the design precludes a second device. The system I want to fix up only has the one 40-pin connection so I wouldn't have the external adapter, or a CD-ROM, or anything since it's occupied by the adapter itself.
If the jumper is to select between the two CFs the same can be done by swapping the cards. The adapter would have to be pulled out either way. The jumper wouldn't be a conveniences feature if so.
The jumper sets which CF card is master and slave. Default is master for the CF card at the side where the power connector is and slave on the other side.
Moving the jumper justs (logically) swaps them around...
A silly feature I agree 🤣 but you never know, there might be a specific need for this feature.
For you just get another CF adapter. There are tons on ebay.
e.g. this one might work for you:
That way you use 1 IDE ribbon cable and 2 IDE to CF adapters. One at the rear (slot bracket) and one inside the case. You can jumper both to set master and slave. Note that you need a floppy power cable for both.
I had to get some molex to Floppy adapters for that!
Got some stuff today. Some of these took ages to arrive. I guess xmas time wasn't the best time 🤣
I got two SB 16 cards. CT2860 which are based on the Vibra 16S chip and come with a real Yamaha OPL3 chip. Apparently this is the last SB16 "design" which comes with a real Yamaha OPL3 chip.
It has line out and speaker out which is quite handy.
Next up are two MMX CPUs.
A desktop MMX 233 and a notebook MMX266
Scored a GUS Max yesterday for $15
Pictures will follow once it's journey over the big ocean has completed.
wrote:Bargain 🤣
Seconded.
Btw shock, I noticed you live in NRW. Do you happen to live anywhere near Warstein by any chance? 😉
