Reply 13860 of 52819, by Brickpad
- Member
Bought this for $41. I am adding this to my collection of Socket 3 PCI boards (3 so far).
Seller's photo:
Seller's photo:
Nice, Brickpad! Congrats...PCI, VLB and coin cell battery. Sweet. Hope it works.
wrote:That looks really strange indeed. Something about it, makes me think industrial board.
It might just be a home/office board though.
It says in the sillkscreen ITOX, a well know manufacturer of industrial computing solutions.
Probably to drive a bunch of ISA interface/controller boards, or ISA serial communication hardware.
wrote:I started stripping down some excess computers I had snagged from a dumpster recently, and I stumbled across a real oddity. http […]
This is a 440BX based Socket 370 board with 6 ISA slots on it! It has on-board Chips 69000 video as well. It is certainly unusual, but I don't know what to do with it..
Yep, you're absolutely right, it's an industrial board 😀
http://www.dfi-itox.com/pages/products/mother … b/itox3spec.php
rkrenicki, you might be interested to know that ITOX still keeps some downloads for that board avaliable after all those years:
Got three socket 3 boards and one dual socket 462 board. Can anyone tell me what boards (make/model) are those 486 boards so I could look up the manuals and configure jumpers? I am not too strong in 486 world 😀
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
The red board is a MSI Master L. I own one, it is a very solid board. Looks like yours needs re-capped. (Same as mine)
Yeah, I found out the Master L info, but nothing on the 486 boards.
Just got a 2GHz Willamette CPU.
My socket423 build will scream! 😀
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Don't the Dells use proprietary motherboard power connectors?
wrote:Don't the Dells use proprietary motherboard power connectors?
Only the pre-P4 models, Dell P4 mobos and newer uses just standard ATX pinouts
Just some boring old RAM...
Plus this LP which I had to get based on the cover art alone 🤣
Hopefully the player that's stashed away somewhere at my grandparents still works...
My builds!
The Underdog - The budget K6
wrote:Picked up this haul of old P4 systems from an architectural office on Long Island yesterday: […]
Pentium 4 systems are dirt cheap now - they're like old CRT televisions, people can barely give them away.
But I've got some plans for these...
What's the story behind the biege one? I don't recognize that model (the rest are Dimension 4000's and a GX400 correct?)
wrote:wrote:Don't the Dells use proprietary motherboard power connectors?
Umm, no. I have a Dell LGA775 motherboard that I can't use because of non-standard power connector. It has IIRC two 8-pin connectors and a 6-pin connector located physically in different parts of the motherboard. There is no standard 20-pin or 24-pin connector.
I/O, I/O,
I/O, I/O
wrote:wrote:wrote:Don't the Dells use proprietary motherboard power connectors?
My 4600, Optiplex 760, and Optiplex 330 all use standard ATX.
@SiliconeClassics
OOOO!!! A HP KAYAK! Those are neat machines! Shame about the rest. Personally, I'd check for anything special and/or upgrades and recycle the remainders.
wrote:My 4600, Optiplex 760, and Optiplex 330 all use standard ATX.
That does not mean that all of them do.
I/O, I/O,
I/O, I/O
Got a nice lot yesterday:
-XT with a FIC PIM-TB10-Z motherboard, 512k of RAM, 20MB hdd that works part time, one 360kb floppy drive, Graphicsmith MGP monochrome/printer card and Hexa I/O plus controller
-the tower is a VIA 4386-VC-C motherboard with a 486 DX2/66, 8M of RAM, 1.2MB and 1.44MB floppy drives, a Cirrus Logic VLB graphic card and a dead Conner 170MB hdd
-Hercules and VGA screens, XT and AT keyboards, serial mices
-the two boxes on the left contains floppies, manuals and some cables.
