Reply 16720 of 52818, by dexvx
wrote:Finally got my hands on one of the later 3dfx cards, the Voodoo4 4500 AGP. Had to clean the heatsink and oil the fan a bit. It replaced a Voodoo3 3000, which had replaced a Creative RIVA TNT/Voodoo 2 combination earlier 🤣 Apparently works nicely with Glide and is a bit better on D3D games than the V3 3000 (+AA). It's in a 440BX/P2@350MHz Slot 1 box. I believe that, while the 350MHz Pentium II was fine for the original gfx card combo, it might bottleneck the V4 4500. What CPU do you feel would be more appropriate for this card?
I think a P2-350 is underpowered even for a V3-3000. To put it in perspective, a V3-3000 operates at 166/166 core/mem. The V4-4500 operates at the same 166/166. Of course it adds a bunch of new performance oriented features, but the fill rate/memory bandwidth limitation is inescapable. Regardless, a V4-4500 is perhaps even rarer than a Voodoo5 5500.
Vogons Voodoo comparison (wish it was done on win98se):
http://www.vogonswiki.com/index.php/3dfx_Benchmarks
AT did CPU scaling (Looks like it takes about a 1GHz P3/K7 to max it at lower res).
http://www.anandtech.com/show/641/10
