Reply 23300 of 52786, by probnot
- Member
wrote:Got this: […]
Got this:
And assorted stuff:
That is a sweet system. Looks to be all original too!
wrote:Got this: […]
Got this:
And assorted stuff:
wrote:The box says the card can do Bus Master PCI and speeds of 133 Mb/s, then manages to contradict itself a few lines lower, so the speed may not be more than 66 Mb/s (or 100 Mb/s, the box is unsure... 🤣 ).
The box is a general one, that's why there's that checkbox in the upper right corner, telling you which speed it actually is.
wrote:Thanks! You could also get a newer Dimension XPS B/R/T/V series or a Dimension 4100 and order the faceplate for the older D/H/P series.
Well.. Either it's my lucky day or miracles do happen because I just found and bought this PC, yes not case but PC, for $12 + S/H
Now the question is, does anyone have a clue what might be in it? I am very unfamiliar with Dimension model PC specs..
wrote:wrote:Thanks! You could also get a newer Dimension XPS B/R/T/V series or a Dimension 4100 and order the faceplate for the older D/H/P series.
Not too familiar myself, but that sound card looks like either an SB Vibra 16 (if ISA) or SB 64 PCI.
In any event it's almost certainly not in original condition, given that second parallel port. I'm intrigued by the network (?) card above the sound card. Maybe it's just an odd photograph, but that doesn't look like BNC to me. Also the bracket above that - SPDIF out or FM radio card...?
wrote:wrote:wrote:Thanks! You could also get a newer Dimension XPS B/R/T/V series or a Dimension 4100 and order the faceplate for the older D/H/P series.
As far as I can tell from a teardown of the system the video card is a Riva 128 and the sound card is an AWE64 Value. The network card is a later add on apparently, a replacement for the PCI modem it came with. The rest of the cards are mysterious, no idea what the second LPT port (or is it an ISA SCSI card?) is doing there but I have a feeling the card on top is an FM radio card.
Pretty sure the sound card is a Turtle Beach Montego AU8820.
It's a Pentium II of some sort, can't read the blue label on top, but it would indicate the processor speed (eg. Dimension XPS D333 is a Pentium II 333MHz).
RAM is PC66 SDRAM, max is 384MB (3x128MB). AGP + PCI + 2xISA ATX mobo.
wrote:Pretty sure the sound card is a Turtle Beach Montego AU8820. […]
Oooh that means the unidentified card is not an FM Radio card but actually a Quadzilla SP/DIF daughtercard for the Montego!
wrote:That is a sweet system. Looks to be all original too!
The guy wanted to throw it away, thank god someone told him to sell it.
ANyone needs some old printer? 😀
"Retro" Music Quest MPU clone by keropi!
A YMF719E-S card I bought arrived finally after ~1.5 months of waiting. Thinking I will use this in my Socket 7 system.
486DX2-66/16MB/S3 Trio32 VLB/SBPro2/GUS
P233 MMX/64MB/Voodoo2/Matrox/YMF719/GUS CD3
Duron 800/256MB/Savage4 Pro/SBLive (IN PROGRESS)
Toshiba 430CDT
Crappy keyboard alert! Why did i buy a crappy cherry rubberdome???
1. Its retro, Made in Germany in 1996!
2. Its exactly what i would have bought in 1996-1999.
3. Its brand new / NOS.
4. Nice retro design with the light and dark keys.
5. Fits my 1997 build perfectly.
6. I already have a G80-3000 HAD.
7. It was 6 Euros.
wrote:"Retro" Music Quest MPU clone by keropi!
allright! nice to see more packages show up! one more to scratch it off the list 😊
enjoy!
Just got a SB16 CT2230 Revision 49432 (the last and best revision). Need to find a CT1748A chip to fit in the socket. It looks a lot better than the photo 😀
This will be going in the 486 build I'm working on, with Win 95 OSR 2.1
Got a Quantum Fireball ST 3.5 series 6.4GB HDD, a Western Digital 10GB HDD, and a Samsung SyncMaster 2333SW 23" monitor (1920×1080) for $40 altogether.
I found a 40x IDE CDROM Drive in box that has never opened. I also bought a Amptron 14" CRT in box -- water damged. I've never heard of this brand, but the bubble screen is nice and it's really light compared to my 17" Viewsonic.
wrote:A very nice SS7 motherboard - AOpen AX59pro […]
With a very nice SS7 CPU in it - AMD K6-3 400Mhz
From someone that has used a few dozen socket7 and SS7 boards in my lifetime, including some that are supposedly "the best", that is my all-time favorite one. Used it for years with no issues. Had a K6-3+ @600 on it. Beast of a system...oh around 17-18 years ago 😀
*Ryzen 9 3900xt, 5700xt, Win10
*Ryzen 7 2700x, Gtx1080, Win10
*FX 9590, Vega64, Win10
*Phenom IIx6 1100T, R9 380, Win7
*QX9770, r9 270x, Win7
*FX60, hd5850, Win7
*XP2400+, ti4600, Win2k
*PPro 200 1mb, banshee, w98
*AMD 5x86, CL , DOS
Never heard of "Amptron"? Surely you've heard of PCchips.
What's more interesting is that Amptron made (or sold branded) CRTs. I thought they only did crappy motherboards.
Picked up a Compaq branded ESS Audiodrive (ES1869) for next to nothing. Waiting for delivery now.
Anyone happen to know if those are full featured, or if they're crippled some way compared to non-OEM-branded ones? Noticed the "Waveblaster header" was missing, but might be enough to solder in a pin header?
It looks exactly like this:
Edit: and while I'm at it, do anyone know what that extra part of the edge connector with three connections to the left is used for? Connections for internal speakers or something like that perhaps?
wrote:Crappy keyboard alert! Why did i buy a crappy cherry rubberdome??? […]
7. It was 6 Euros.
I totally agree with your line of thinking - that's why I've gotten meself two (also, they have Highscreen logo, so they'll go nicely with my Highscreen build):
wrote:Never heard of "Amptron"? Surely you've heard of PCchips.
If I had, I've forgotten. 😀 But I do recall PCchips.
I just realized that this monitor doesn't have any brightness controls, so I'm going to probably have to open it up to see if I can find those little knobs. I like the size of the monitor, it's just washed out compared to my Viewsonic, -- which has a great picture. It also has a built in speaker amp -- which requires a separate power adapter. And on the back, I think the line-in was mislabeled mic-out. And the VGA and power cable are attached to the monitor, something I've never encountered.
EDIT. I just found out how to adjust the contrast and brightness, so now the picture looks great all bubbly.
