Reply 24440 of 52813, by bjwil1991
Don't know if radios count or not. But, here we go.
Gallery: http://imgur.com/gallery/P5gKLLg
Reply 24441 of 52813, by blurks
That battery compartment looks strange. What kind of batteries are you supposed to stick in there? Metal plates also look suspiciously glossy to me. Seems to be a recent home-made modification if you ask me.
Reply 24442 of 52813, by bjwil1991
I hooked up a 9V battery to the radio (using 2 sets of test leads with a wire on each lead) and it works.
Reply 24443 of 52813, by dionb
Looks like it would have originally housed some lead-acid battery, but modded to take four D batteries. Which would supply 9V, so no surprise that a 9V brick works.
Reply 24445 of 52813, by Predator99
Just won this auction:
155.17 KiB
43.58 KiB
Its an original IBM EGA and the 5170 80286 Mainboard. And an ISA VGA, hopefully a TSENG.
Then I noticed another auction of the same seller:
342.25 KiB
For sure I also had to win this one...! At least all pins seems to be ok, therefore I assume the condition of the MB is also OK...
Reply 24447 of 52813, by lolo799
furan wrote:
Roland SCP-55 in shrinkwrap (Japanese packaging). https://i.imgur.com/lIf5E1y.png […]
It's a great card, if you end up using it!
Does it come with the breakout box?
Reply 24448 of 52813, by JidaiGeki
MCB-3 on the outer box suggests it does, my boxed SCP-55 (Oceania, I presume = US?) didn't ... took me 20 years to track down the MCB-3 by itself!
Reply 24449 of 52813, by Batyra
^ I love those japaneese boxes…
Meanwhile a few days ago I got this. 586ITOX industrial motherboard ATX - great for big soundcards configuration.
692.42 KiB
586ITOX
Reply 24451 of 52813, by Ozzuneoj
bjwil1991 wrote:
Don't know if radios count or not. But, here we go. […]
It looks like its crying out in terror. 😲
Reply 24452 of 52813, by Intel486dx33
Lucky Star 5A A1 Socket 7 motherboard with pentium 166mhz and 8mb ram.
Via chipset.
Baby AT ( really small form factor ).
8.75" x 8.75"
    1.43 MiB
    1.7 MiB
    465.35 KiB
Reply 24453 of 52813, by elod
Check the caps. One of my Lucky Stars had them quite literally fall off (yes, the thru hole ones).
Reply 24454 of 52813, by Gered
Didn't really need another laptop, but as I'm a big fan of IBM Thinkpads, I didn't want to pass this one up when it showed up locally for relatively cheap.
Thinkpad 760ED. Pentium 133, 32MB RAM, 1024x768 XGA TFT, 2.1 GB HDD, 6x CD-ROM, external floppy drive, and a battery that surprisingly still works. Appears to have been used by the science department for a local high school back from 1997 until 2008. Judging by some of the files that were left on it, by the end of it's time at that school it was being used solely to track inventory for one or more of the science labs at the school.
Unfortunately this is one of those Thinkpads with the dreaded MWave audio. Mostly doesn't sound too terrible. Though Doom E1M1 is noticeably bad in parts and as an added bonus causes the whole system to lock up (regardless of whether I'm booted into Windows or DOS). I've heard it might be possible to swap the sound card out for one of the ESS variants that appeared in certain other 760-models? Anyone here done this by chance?
The BIOS is several versions out of date from what I can see (Feb 1997). Additionally, a number of the drivers that are installed also look to be earlier versions so it's possible I can see some improvements by just doing a fresh install with all the latest driver/BIOS versions *fingers-crossed*.
Finally, I'll add that this has possibly the worst 640x480 / 640x400 screen scaling that I've seen. It's a 1024x768 native display and it looks like it's scaling up to 800x600 only, leaving some leftover black borders all around. Just terrible honestly, haha. Not sure if I will really use this long-term because of that alone. Which is a shame, as for a DOS machine I really like the little LCD display with battery status, etc. on it. Plus I much prefer the trackpoint and mouse buttons on this as compared to my Toshiba. And I generally prefer the keyboard layout on these Thinkpads, but that's not a big deal.
Doesn't look like it will de-throne my Toshiba 430CDT as my portable Win95/DOS machine unless some BIOS/driver updates drastically improve things. 😀
486DX2-66/16MB/S3 Trio32 VLB/SBPro2/GUS
P233 MMX/64MB/Voodoo2/Matrox/YMF719/GUS CD3
Duron 800/256MB/Savage4 Pro/SBLive (IN PROGRESS)
Toshiba 430CDT
Reply 24455 of 52813, by root42
4*1.5V=6V. I think you meant six D cell batteries, right? Would probably last a bit longer than one 9V E block!
YouTube and Bonus
Reply 24456 of 52813, by luckybob
Got one of these guys 'cheap': https://www.ebay.com/itm/142877448698
It is a 1GB "industrial" SSD for scsi. Might not be as good as the scsi2sd project, might be better. I will have to do a bit of benchmarking to find out.
Reply 24457 of 52813, by henryVK
I just sold a Thinkpad 770 that I got a few weeks back. It comes with a CirrusLogic Crystal Audio chip but has the same scaling-issue with it's XGA display. What bothered me even more is the grimy feel tha the rubberized surface had acquired. I read that it is possible to renew this with some product or other (after scraping the old rubber off), but I wasn't going to bother because of the display.
I have since completely disassembled my Toshiba Tecra 510CDT in order to replace that noisy fan. It has about a 100 screws to it and all components are just stacked on top of one another like so many pancakes.. wish I had taken a picture of the mess. I was sweating bullets too, but in the end it wasn't too hard doing it with the maintenace manual, it just took a good long time to reassemble. Maybe I can still find a tool for fan speed control for this one.
Anyway, I'm happily playing Doom 2 and finally finishing the last chapter of Betrayal at Krondor on this one, sitting in my living room and looking out into the garden.
Reply 24458 of 52813, by Katmai500
Grabbed a Radeon X800 XT Platinum Edition AGP card. It looks like it will need a thorough cleaning from the seller's photo, but it's tested and working. The "Platinum Edition" moniker always seemed out of place and a bit funny to me. It feels like the start of the era of crazy video card naming. I still remember wanting one of these pretty bad back in 2004.
It looks like it's missing a capacitor right next to the molex connector. Does anyone know the specs on that capacitor so I could source a replacement? 😀
    180.69 KiB
Reply 24459 of 52813, by Shagittarius
I bought an X800 XTPE the day it was released originally, got a free Tshirt with it too. This is the only video card I've ever had die on me, so be careful. The Tshirt is good though I still wear it often.
