Reply 25160 of 52811, by Thallanor
derSammler wrote:
ATI 3D Rage Pro PCI w/svideo in, composite in, and TV out, and full memory expansion
Mac version. That one won't work in a PC until re-flashed with a PC-compatible firmware.
The S3 card is nice. 😀
Yeah, that flash process makes me nervous because I have no idea what I'm doing. So not sure what I'll do...
Reply 25161 of 52811, by Thallanor
Also, got a message from kixs regarding some hardware pertaining to this thread but I don't have enough posts yet to reply. Sorry! 😁 I'll keep replying and will eventually be able to. 😀
Reply 25162 of 52811, by SEGamer
appiah4 wrote:
SEGamer wrote:
F2bnp wrote:
If it's not too much trouble, would you mind checking the Matrox driver disk that came with that Mystique for this video?
This is apparently an interlaced video that runs at 60 fields per second and I've been looking for it for a while now, because it's a nice showcase for video playback on early Pentiums 😀.
I put all of the videos in an archive here: https://www.dropbox.com/s/9wtovyp43ygra0f/Mat … ique%20Promo.7z
Should be 5 total, each are the same except for the text effects are in different languages. Now you can enjoy this video around the world!
Could you possibly share a full image of the driver cd?
Sorry, been dragging my feet on this. Added it to the drivers thread here - Re: VOGONS Driver Library
NintendoAge | VCFed
Reply 25163 of 52811, by buff
I recently took a chance on a mother board lot on Ebay.
7 motherboards, "some work some have issues". I saw some SD-RAM boards, including one with an ISA slot. Took a chance and bought the lot for $45 shipped.
Included were:
Shuttle AV18V31 s370 board.VIA Apollo Pro 133T chipset. Included a Tuleron 1400 under the heatsink and 3x PC133 CL3. Works fine so far.
Already grabbed a Tualatin P3 1400/512K off of ebay for $10 for it (so much faster), and a Radeon 32MB DDR. Currently in a vintage case was a Sound Blaster Live!.
1.45 MiB
Soyo P4x400 Dragon Lite. VIA Apollo P4X400. Included a P4 2.8/512/533 and 1x 512MB PC2100 DDR. Works, one bulging cap near AGP slot.
1.76 MiB
Asrock M266 s478 board. Supports DDR2100 as well as SDRAM. Included a Celery 1.8 and 1x 512MB + 1x 256MB DDR. Works, and that celeron is incredibly slow.
1.74 MiB
FIC PTM 865 / 848 S775 board. Intel 865G / DDR board. Included Celeron D 3.46Ghz/512/533. Untested
1.9 MiB
Asrock G41M-LE DDR2 / 775 board. Untested
1.73 MiB
ECS 945GCT-M3 DDR2 / 775 board. Untested
ECS AM2+ I-Cafe IC780M-A. Tested and has issues. Also, don't care about this board.
Reply 25164 of 52811, by arncht
2003q2 goodness 😀
Asus A7N8X Deluxe rev 2.0 NVIDIA nForce2 Ultra 400
AMD Athlon XP 3200+ AXDA3200DKV4E
Samsung PC3200 DDR 256M x2
    1.59 MiB
    450.48 KiB
Overdoze of the demoscene
Reply 25165 of 52811, by appiah4
Got these motherboards and CPUs on Friday. All tested and working, even though the little Athlon chip has had a lot of chipping..
Fİnally owning a Socket A board with an ISA slot feels good.
Reply 25166 of 52811, by Thallanor
I picked up an ISA HDD/FDD/serial port/parallel port/gameport card so I can hopefully get high density drives working on my Tandy. Also picked up just a serial/parallel/gameport ISA card for another computer. Whoo.
Reply 25167 of 52811, by xjas
Lots of Socket A love in this thread right now. I've been really happy with the performance of my Shuttle XPC Win98 lunchbox, but less than happy with the amount of heat that comes out the back of it. So I impulse-bought a Geode NX1750 this morning (while lying in bed surfing the big auction site with my laptop - BAD habit which I should probably not do. 😜)
Should be a direct swap-in for the AthlonXP 1700+ that's already in there. I'll update the thread with some before/after temps when it gets here. It's coming from a semi-local town so shipping shouldn't take long.
Reply 25168 of 52811, by mcobit
Got a P233 Notebook from the flea market recently.
In great condition only BIOS battery empty.
860.4 KiB
Reply 25169 of 52811, by WildW
Picked up this silver beauty today after buying on eBay for 10 of my local currencies. I was able to figure out that it was a P4 machine on an 865G chipset with Windows 98 drivers, but I couldn't tell what GPU was inside other than knowing it would be AGP. Turned out to be a Radeon 4650 and now I'm doing a small happy-dance 😊
Has Windows 7 Ultimate on there but I think I may make it into an XP lan-party box for gaming with my hypothetical friends. The poor thing has been a neglected media-player for years.
Reply 25170 of 52811, by Munx
Got myself a CRT for €5.
497.4 KiB
546.88 KiB
I now consider those €5 wasted. Every time I turn it on it makes a REALLY loud buzzer sound that actually shakes my table as well as the image. The time it took to take the attached images was more than enough sphincter clenching time for me and it will go to a recycler tomorrow.
My builds!
The Underdog - The budget K6
Reply 25171 of 52811, by derSammler
That's called degaussing. It's done to demagnetize the tube. All larger monitors do this (unless they are cheap crap).
Reply 25172 of 52811, by probnot
Munx wrote:
Got myself a CRT for €5. […]
Looks like it's from the mid-2000's era, when the only CRTs sold were low end build quality for people who couldn't afford LCDs. That said, it looks ok from the pictures.
Reply 25173 of 52811, by Munx
I've never seen a monitor do it this violently.
That said, I will hold off from getting rid of it for a bit and read up on this model just in case.
My builds!
Reply 25174 of 52811, by keropi
oh that's normal , even my 14" PVM makes a loud degauss sound: it's how you know you have a good monitor 😁
Reply 25175 of 52811, by dionb
Oh dear... you know how trying to dig up one hard-to-find component sometimes results in needing to get the whole system - which then still leaves you with that one component missing from one of the two?
My search for an Olivetti M24 keyboard has led to me doing an exchange of a huge Cisco PoE Gb Ethernet switch for a complete Olivetti M240 with keyboard. It will take a while before we can actually do the deal as predictably (variant on Murphy's Law) the other bloke lives at one end of the country and I recently had to choose between work there or at the diametrically opposite end of the country. Guess which I chose...
I'm not even totally sure the M240 has the same non-standard keyboard protocol as the M24, but it also uses a DE9 connector, so quite likely. Worst-case it's not compatible and I have another (still oddball but slightly closer to 5160-normal) XT with CGA monitor. Will post pics when I finally get it here.
Reply 25176 of 52811, by MKT_Gundam
I got this "gamer" case:
It has a lot of rust and scratches, but for 2 dollars it was a great find.
I will use for my win 98/xp ultimate build.
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 25177 of 52811, by liqmat
I picked up four bad monitors so far this month and I just found out my county has stopped recycling monitors and now just throws them in the landfill. I was a little surprised by that.
Reply 25178 of 52811, by appiah4
MKT_Gundam wrote:
I got this "gamer" case: https://preview.ibb.co/bHPm2K/Case1.jpg https://thumb.ibb.co/h2Dh9z/case2.jpg It has a lot of rust and […]
Haha, this got me thinking: the RGB craze of the 2010s will look just as absurd as these in another decade.
Reply 25179 of 52811, by MKT_Gundam
A friend of mine still have X-blade case:
https://www.youtube.com/watch?v=k3RnGgKNGwE
