Reply 27180 of 52859, by Muppets4
SpeedySPCFan wrote:
Muppets4 wrote:
A lovely jvc tm-h1700g video monitor. With composite and s-video connections. It lacks RGB, but makes more then up for that with 750 lines horizontal resolution. Now I have to wait until my s-video cables come in.
Another JVC monitor here in the span of a few days... yours wouldn't happen to come from Lynnwood, WA, would it? The JVC I picked up just a few days ago and posted here came from there 🤣
No, I picked it up myself in Leiden. A Dutch city 😀
Reply 27181 of 52859, by wiretap
Purchased this SBC industrial PC for $25 shipped last night.. supposedly has a 386 in it and boots to BIOS according to the seller. For the price, I couldn't pass it up since it is hard to even find a case with backplane for that cheap. I think I'll paint this one black with a black Gotek in the front.
My Github
Circuit Board Repair Manuals
Reply 27182 of 52859, by luckybob
@wiretap
To me, that power supply screams Pentium 2/3 era, but the tag says "wi star 66".
Probably a 486/66.
Reply 27185 of 52859, by dionb
Big day today.
First off the little stuff:
A pretty generic 1993 486 board with So1 LIF, VLB, 8x 30b SIMM, 64k cache and a 486DX2-66 on it. The reason i bought it: seller pic gave a closeup of the first SIMM: 9 4Mb chips. And indeed 4x 4MB parity, with 4x 1MB behind it. Highly remarkable: not only is there no corrosion on the battery, the 26-year old barrel (date code december 1993) still holds a charge and saves BIOS settings 😮
To the left: an MCE2VGA adapter, the next best thing to a good EGA monitor (which I declare to be a unicorn, at least locally and at a price I'm prepared to pay, after 6 months futile searching). Of course, I didn't order an EGA monitor cable as I assumed at least one of my many serial cables would be fully wired straight through... Murphy says: no EGA today. Have to wait until my cable arrives before I can show Skeletor in full EGA glory.
Fortunately I can show Skeletor at significantly higher resolution on today's big catch:
That's 1280x960 Skeletor not even coming close to filling the screen. SGI 1600SW, connected to the Number Nine Revolution IV-1600SW I picked up a while ago.The best 1998-vintage (or indeed anywhere in the 1990s) TFT bar none. 110ppi, beating a contemporary 24" full HD monitor by about 20% - not bad after two decades 😉
Oh, and that thing in the shadows behind it? A second one 😜
- now to find a second card supporting OpenLDI, or even better a Pixlink/Multilink adapter...
Reply 27186 of 52859, by keropi
^ The ega cable you need must be wired as 1:1 , so those serial cables must have some cables inverted, if you cut one DB9 connector and solder you own with a 1:1 configuration you'll get it going 😀
nice stuff you got there btw 😁
Reply 27187 of 52859, by dionb
Not just inverted, they're not fully wired up. Multiple pins don't go anywhere. First thing I did was chopped one - only five wires in the cable.
Oh yes 😀
Reply 27188 of 52859, by arncht
dionb wrote:
Big day today. […]
Big day today.
sis461?
Overdoze of the demoscene
Reply 27189 of 52859, by bjwil1991
Bought the following yesterday on my thrifting adventures:
eMachines T3116
Microsoft Intellimouse PS/2 and Serial (might as well have a spare)
Received the following in the mail from Digi-Key:
4x 12ns 32Kx8 SRAM
1x 15ns 32Kx8 SRAM
30x 16V 10ųF SMD caps*
20x 25V 68ųF SMD caps**
10x 6.3V 22ųF SMD caps**
10x 6.3V 56ųF SMD caps**
10x (might be less) 10V 16ųF through-hole caps***
5x Solder wick/braid
2x 28-pin socket for my Creative Labs CR-563-B CD-ROM drive to install the firmware EPROM
* for the VooDoo2 card
** for the ASUS X54C motherboard
*** for the Sound Blaster Live! 5.1 card since I borrowed 2 of them for my VooDoo2 card, which didn't work too well.
Reply 27190 of 52859, by dionb
arncht wrote:
dionb wrote:
Big day today.
sis461?
Not quite:
Reply 27191 of 52859, by Ozzuneoj
wiretap wrote:
Yea sometimes I just buy things for the mystery factor. 🤣 We'll see once it arrives.
I saw that too. I was very tempted to grab it myself, but I've made way too many purchases lately and I need to slow down and take the time to actually sort, test, and use\resell things. I have a few threads I need to start or update already. 😵
Let us know what you find when you get it! 😀
Reply 27192 of 52859, by cyclone3d
luckybob wrote:
@wiretap
Probably a 486/66.
I saw it and wondered who bought it.
It is definitely an system with a backplane and a CPU card.. so if they say it boots to a 386 BIOS, my guess it is an ISA backplane with a 386 CPU card (SBC) in it. I guess it could also be a 386 CPU card with an upgrade to a 486 66 CPU in it as well.
Definitely interested in hearing/seeing what is really in it.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 27193 of 52859, by Predator99
Monitoring auctions since about 2 years now, but never spotted one. And then this 😲 Now its mine..mine...mine, but without mobiles and spoons 😎
    350.75 KiB
Reply 27195 of 52859, by Cyrix200+
luckybob wrote:
@predator99
That does look like a nice parallel port pci card. Not that common!
And an OAK VGA! Also very nice.
1982 to 2001
Reply 27199 of 52859, by Baoran
I bought a cheap tseng et4000ax ISA card from ebay which has not arrived, but there is something strange. I checked the shipment tracking and it has just arrived to my country. Main thing that worries me is that measurements of the package 16cm x 41cm x 13cm and weight of the package is 5Kg. I have no idea what I will be getting when I am suppose to get a small ISA card but package weights 5Kg...
