Ultrax wrote:I plan on upgrading the RAM in mine at some point, along with getting the CF-IDE adapter. I still need to test my battery. I find it funny how many Librettos still have functional batteries - Toshiba must have made them well!
Mine is sitting at its stock 16 MB, as indicated by the photo of the BIOS the seller sent to me (they borrowed a cord and got it powered on). Like I said, that will likely change soon. Are the RAM modules particularly expensive?
I find it hard to believe Toshiba somehow managed to cram a full Pentium MMX PC into a case this small, with very little compromises!
The RAM upgrade is only really useful for 98 / 2000. It is overkill for DOS/3.x, and it feels like overkill for 95... But for 98/SE, 2000, ME, it really feels required.
I'm not sure how expensive they are, they seem like they're relatively common (They use a standard Toshiba connector, like you'd find on a Satellite Pro, but about half the length. You could probably get a 32MB card to fit if you really wanted to.
Be warned, some CF-IDEs do not play well with the onboard ATA, and some will not even fit behind the plastic cover and will break it.
It's not just Librettos! I have some other old Toshiba laptops (NiCd, NiMH batteries) which also still hold... A charge. Granted, they typically can only work for 5-10 minutes (maybe 20 in standby mode), but it's more than can be said for a lot of machines of that age. Oh yeah, and they're standard sized cells - You can easily replace them if need be!
The only real compromise I can think of is the severe lack of ports on the machine. The mouse also sucks, even though it is the most pleasant trackpoint I've ever used. The display, while very VERY nice (amazing color and pretty damn bright, it's matte finish too so it doesn't get much glare!), is only 640x480. At least it supports pseudo-resolution, but the scrolling is kinda annoying if you ask me.
A few tips: Get a decent CF-IDE adapter, put a 4GB CF card in, put DOS on the CF card FIRST using a PCMCIA diskette drive or some other utility on a modern machine, then drop some CD-ROM software onto it and use a parallel / PCMCIA CD-ROM drive to install Windows 95. I can get you a copy of the Toshiba software from mine if you can't find it online, it's almost required (Tells battery levels, screen settings, system configuration, power options, sets a lot of BIOS options, and manages PCMCIA cards).
