Reply 35180 of 52760, by Horun
- l33t++
appiah4 wrote on 2020-07-20, 11:59:I had happily bought a very cheap ASUS PVI-486SP3 PCI/VLB Socket 3 motherboard, but once I received it I noticed something that I hadn't when looking at the item's potato photos, a burnt pin on the CPU socket. So tell me Vogons, does this mean there is no hope for this board? Could it be just the plastc that's burnt? Would a socket change be in order? Or would it be a lost cause regardless?
You can remove the C ring on the end and then slide the handle out. Slide the top back as far as it goes and the top should come off (have removed those type a few times before). I do see two broken pins or wires sticking out of some holes top left side. Good luck !
Also today bought a 50 pack of 1x-24x CDR for $3.50 but got 50% off so cost me $1.75, local SA store. Hopefully they are readable in 4x and 8x old cdroms, will have to test one and make a note...no picture as am sure you all know what a spindle of blank cdr look like hahaaa
