Reply 35280 of 52818, by pete8475
devius wrote on 2020-07-31, 09:05:
pete8475 wrote on 2020-07-30, 20:02:
He also has an Asus P2-99B AT motherboard, but there is a blown capacitor on it, so I didn't take it.
What??? Blasphemy!
imi wrote on 2020-07-31, 10:37:
I'd take it :p
that sure is worth to repair ^^
hahaha
Alright guys I'll grab it next time I'm there.
I've never been great with a soldering iron but I guess I'll make a thread about attempting to repair that board when I have it.
Reply 35281 of 52818, by NyLan
I found and bought on eBay some speaker I had 25 years ago with my first Pentium 75 ! So happy to get it, the picture was clean and clearly white... but when I received them, I've been disappointed to see this yellowish color 🙁 Only 5$, but still...
A "magic" bath with Hydrogen peroxide later...
Now I can really enjoy them 😀
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
Reply 35282 of 52818, by rikukos
Lately, I've been a bit lazy about posting on this thread but this was easy enough to take pictures of ha-ha:
Roland MPU-IMC (Microchannel, Boxed). I have this (bare) but boxed ones show up rarely so I felt it was worth picking up imho.
Reply 35283 of 52818, by Intel486dx33
Macintosh speakers.
These actually sound pretty good for there age.
Works great with my iPad too.
Reply 35284 of 52818, by Warlord
rikukos wrote on 2020-07-31, 17:37:
Lately, I've been a bit lazy about posting on this thread but this was easy enough to take pictures of ha-ha: […]
If you are into ibm micro channel stuff, i guess thats the card to have. you have to be into it tho cuz its useless without that.
Reply 35285 of 52818, by pete8475
pete8475 wrote on 2020-07-31, 15:21:
hahaha […]
What??? Blasphemy!
I'd take it :p
hahaha
Motherboard obtained. Along with a Geforce 2 MX400 64MB AGP card. Attached pics show board and bad cap. The motherboard looks brand new except for that one bad cap.
If I can replace that capacitor and get the board working I'll likely replace my K6-2 machine with this and a Pentium 3 600.
    836.46 KiB
    978.47 KiB
Reply 35286 of 52818, by imi
*gasp*
speaking of microchannel stuff, I picked up this PS/2 56slc with 486slc2 processor upgrade :3c
... the power supply is borkd though, I hope the rest is ok, no cards unfortunately ^^
148.68 KiB
also my second 8" floppy arrived... it was supposed to be a pristine Mitsubishi M2896-63-02M double sided double density 8" drive including an adapter.
...but shipping was not kind to it :'(
113.69 KiB
I don't know if the metal bracket hurt or prevented even more damage, the metal bracket got bent and the front panel broke in several places and got stuck underneath, also the pristine cardboard protector got pretty roughed up
in hindsight it was wise that I asked the seller to unplug the adapter from the drive as to reduce the risk of it breaking the connector/PCB at the back by sticking out during shipping.
the front should be fixable, one of the posts holding it to the drive at the back shattered and idk if I found all the pieces... but seeing as it got bumped very hard probably idk if everything is still going to be in alignment, at least it did have the cardboard protector.
209.34 KiB
pete8475 wrote on 2020-07-31, 18:48:
that should be an easy fix, it might actually still work with that cap anyways, though I'd be safe and replace it before trying ^^
Reply 35287 of 52818, by rikukos
imi wrote on 2020-07-31, 18:51:
56 SLC is a lovely machine, especially with the CPU upgrade installed. Built like a tank and takes 16 MB on planar - also fairly spacious for such a compact form factor (me likes : ) Did I mention SCSI onboard - lovely! Congrats!
Reply 35288 of 52818, by pete8475
Hopefully!
It was very easy to desolder the cap and I've ordered a new one from digikey.
Reply 35289 of 52818, by Turbo ->
Mostly I am hoarding. Bought two AMD systems from around 2002. I've taken apart the computers, and this is what I got. I like very much PC fan controller, external drive bay, and the arctic cooler mounted on AGP Radeon 9600 card. MSI motherboard needs recapping (one day 😀 ) Funny thing when I was removing DDR Ram I saw the one with heatsink from sides. I thought: "oh how nice ". When I grabbed in my hand: plastic 😀
    368.55 KiB
    405.89 KiB
    510.28 KiB
    207.78 KiB
Reply 35290 of 52818, by badmojo
NyLan wrote on 2020-07-31, 16:56:
Wow great result! I've tossed out some great stuff over the years because of yellow, dang it.
Reply 35291 of 52818, by Standard Def Steve
Turbo -> wrote on 2020-07-31, 21:07:
Even though Rambus hasn't been relevant since the turn of the millennium, I still associate RAMsinks with RDRAM. It wasn't till I scrolled up a bit and actually read your post that I realized the module in your last picture was DDR. 😜
Reply 35292 of 52818, by Artex
Nice work! I just switched over to the 12% peroxide bath + UV light method vs developer cream + plastic wrap myself. Works well - nice and uniform restoration vs streaking.
Reply 35293 of 52818, by EvieSigma
rikukos wrote on 2020-07-31, 19:55:
Like imi, the PSU in my 56 (486SLC2 at...50MHz? Yeah, 50MHz) is also borked, all it does is make a high pitched whine if you plug power in. And there's a ton of surface rust inside the case that I'm not really sure how to handle...
Reply 35295 of 52818, by Artex
chrismeyer6 wrote on 2020-08-01, 01:39:
If it's just surface rust you can treat it with CLR or a similar rust remover.
+ baking soda!
Reply 35297 of 52818, by gdjacobs
hahaha
"You know how to get to Carnegie Hall, don't ya?"
Reply 35298 of 52818, by EvieSigma
I was actually thinking Evaporust, but CLR would probably work too!
Part of the problem is that the motor for the floppy drive also has some serious surface rust and that would be much harder to clean...
Reply 35299 of 52818, by pete8475
gdjacobs wrote on 2020-08-01, 02:02:
https://i3.ytimg.com/vi/XNAF5pAQENI/hqdefault.jpg "You know how to get to Carnegie Hall, don't ya?" […]
hahaha
hah yep.
