This Chieftec (Antec Clone) tower arrived today, and I'm really impressed by how clean it is! Looks like it was just taken out of the box for the first time. I'll probably use it for a P3 build of some sort. Came with a power supply, CD-ROM drive, floppy drive and a handful of random internal cables.
Another complete tower I picked up not long ago. I couldn't resist this one because it's almost identical to the very first PC I had back in 1997 (it would be hilarious if it was the same one!) so I had to jump on it. Sporting an AMD K6 233 MHz and I think 16 MB RAM, and I think a Rage Pro video card. Perfect Win 95/DOS platform.
My PATA/SATA converter arrived today so I finally managed to test everything. After testing I installed Windows Xp and booted up some games and everything works perfect. Now I wait for the case to arrive.
Good thinking, you don't want to be like those poor suckers who are stuck without having a working Betamax.
... wait that might include me, I haven't had it out in a decade plus, the belts probably rotted off. ... wait again... it's two moves since I saw it, that's not promising.
It's too soon to call, so I'm hedging my bets on the HD video format war
Nice. I actually have one of those which I bought new years ago, just before they stopped being made. You can use an older version of Cyberlink PowerDVD to watch HD-DVDs if you have any.
Been on a bit of a tear recently, must be the continued social restrictions and lack of travel.
Picked up, in no particular order, the following:
Compaq LTE 5200
IBM Thinkpad 755CD
InWin A500 (it came bundled with a PIII-800Mhz (Celeron?), an Asus P3B-F, 384MB RAM, a 13GB Maxtor HDD and an LG spinner - none of which I’m too fussed about, really)
DFI LanParty NF4 Ultra-D with 3700+ and 2GB OCZ Platinum (really about the MB and backup sticks of Platinum to match mine)
In there is an adaptec SCSI card that has magically transformed in to a Macintosh version using nothing more than an official firmware update utility in OS9, an S3 decelerator, a Something-Happens-Here ISA card, and two 3com PCI ethernet cards.
For the non-card parts, I also got a 4.55GB Wide-SCSI IBM drive, a pathetic for 1999 350MHz PII, a 32x SCSI CD-ROM drive, and a floppy. Of course, in the back is something oddly interesting.
Your ISA card appears to be a terminal adapter, not sure if it's 4 into 1 or those are dual uarts and it's 8 into 1. Buy the breakout, connect all your sub 486 systems into a serial octopus of pwnage. 🤣
A couple of arrivals today. First, a NIB Zalman 300 watt power supply which will be great for any of my late 90s - early 00s systems.
Also received a NIB TDK VeloCD 52x CD drive. This is one of the few items I actually walked into Best Buy and paid retail for back in the day when I was still rocking my AMD 1.2 GHz Thunderbird PC, because it's a phenomenal CD drive and produced perfect quality dumps of PSX games and audio CDs. Brings back memories. This is the 2nd of these NIB I've bought, but the other one I think is a 48x or 40x read.
Got this machine primarily for the case since it has threads for both AT and ATX. And the Fluke for fun. It was actually a rather nice machine. Aopen AX6BC motherboard with P2 350, 128MB, 850MB HDD and S3 virge.
Also got a Great Planes Real Flight G3 simulator for RC planes/helis.
Is that the one like an RC transmitter, apart from it's got a USB cable instead of an antenna? I picked up something like that a couple of years back to learn myself some stick wiggling skillz, but didn't have a lot of time to play and the one trainer I found to run wasn't very good... res wasn't very high and the plane turned into a blue blob at a very shallow depth away from you. So let me know if you find any good freebies, and I'll have another crack sometime.
