First post, by tikbalang
esstech installers need win9x to install. here are some i have tested under DOS.
http://www.mediafire.com/?xedx9bygyb6
essdos.zip
a collection of esstech pci soundcard drivers for DOS.
es1938 ESS 1938/41/46 Solo-1 AudioDrive (16bit)
es1941 ESS 1938/41/46 Solo-1 AudioDrive (16bit)
es1946 ESS 1938/41/46 Solo-1 AudioDrive (16bit)
es1968 ESS 1968 Maestro-2 AudioDrive (16bit)
es1978 ESS 1978 Maestro AudioDrive (16bit)
es1980 ESS 1980 Maestro-3 AudioDrive (16bit)
es1989 ESS 1989 Allegro-1 AudioDrive (16bit)
ripped from:
ESS Technology (http://www.esstech.com)
config.sys
DEVICEHIGH=C:\ESS*****.SYS
autoexec.bat
LH C:\ESS*****.COM
    ESSDOS.zip
    111.85 KiB
    3187 downloads
    essdos.zip
    *** more ***
Reply 2 of 7, by collector
This forum is for DOS games not hardware and its drivers. All old hardware, drivers and its configuration should be asked in Marvin.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 3 of 7, by Stiletto
Moved.
Niezgodka, please knock it off with the bumping ancient threads, thanks. 😀
do the Fandango!" - Queen
Stiletto
Reply 4 of 7, by Windows9566
Its too quiet for me, i can barely hear the fm synth and can somewhat hear the digitized sound
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 6 of 7, by CMDLineKing
I know this is an ancient bump, but every time I searched to resolve this issue, this thread came up in the results. tikbalang had gotten results that I could not, but I couldn't replicate what he was doing to successfully have the DOS Drivers recognized. I kept at it and after a couple of hours of trial and error (and reboots), I got it!
Turns out it's simple, as long as you're booting into Win98/95.
Download the VXD Version of your ESS Driver.
Uninstall your old drivers, re-install with VXD and force them/choose your driver to use and point to the VXD one. If you get the option of 4 compatible items, choose the one that says "Device Manager" in the name version first, the others will auto detect after that.
You should get a ESSAUDIO.COM and ESSAUDIO.SYS in your C:\ Root. The driver will also update your AUTOEXEC.BAT and the CONFIG.SYS so you can use the driver in DOS Mode.
Boot into 95/98 DOS Mode or Real DOS. Once the driver initializes in DOS it will generate the "ESSAUDIO.INI" that has been missing!
Now you just need to save the three ESSAUDIO files and the lines from your CONFIG.SYS and AUTOEXEC.BAT and you'll be good to do an install again anytime. I was working on this for a Gateway SOLO 5300 laptop and successfully am running my old DOS games without having to mess with windows or use PC Speaker. I may try to experiment with VXD driver to see if I can adjust any settings VIA Windows and if the INI Breaks or something,
I found VXD Drivers for my ESSAUDIO 1980 Maestro 3 here:
http://www.opendrivers.com/download/driver-11047.html
Reply 7 of 7, by guest_2
I can confirm the ESS198X VXD drivers do not work with a Dell Inspiron 8100, or at least I havent managed to get them working yet.
The Dell Inspiron 8100 / Latitude C810 uses ESS Maestro 3i
Driver on the Dell website Ive been using is 'ESS Maestro 3i (Audio Only), v. 5.12.01.1165, A06'
I've managed to get the ESS Maestro-3 Device Manager, ESS Maestro-3 PCI AudioDrive and ESS Maestro-3 DOS Emulaton drivers installed. This does add the required files in C: root and updates the autoexec .exe and config.sys however launching anything audio related in Windows 98 SE crashes the machine, either BSOD or hard freeze. Even going into Multimedia in control panel and access advanced properties causes it to crash
