Best PCI performance...
First post, by Amigaz
Been inspired by 5u3's thread about his rigs where he bench several PCI cards in his 486 system with the benchmark prog pcplayer bench.
I was hoping to see more contributions by other in that thread so I made this thread so maybe the testing will continue? 😉
Have gathered alot of different PCI cards during my time as "gatherer of old computer junk" so I have alot of different cards with different chipset.
during the following days I'm going to bench the cards I have....but I think I've found the winner though 😁
score 9.0 without unive, 9.1 with univbe
The weird thing is that my system I used is quite dated, an MSI MS-4134 which is one of the first PCI based socket 3 motherboards 😮
Just using a DX4 100mhz
The videocard I used was a Matrox MGA 1064SG Mystique 4mb
Here's the other member's tests
My oldschool rigs (updated once again)
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 1 of 33, by 5u3
Nice score 😉
With 120 MHz it probably could crack the 11 FPS barrier...
What chipset is on the board?
And I'm supporting your call for benchmark results. Come on, 486 owners, let's find out what combination is fastest!
Reply 2 of 33, by Amigaz
5u3 wrote:
Nice score :wink: With 120 MHz it probably could crack the 11 FPS barrier... What chipset is on the board? […]
Nice score 😉
My plan is to put a beefier CPU on it using my voltage adapter but I think the ancient Ami colour BIOS which I think is the last week/month it was used will cause problems with for example an AMD 5x86
Chipset? uhh....look below 😀
They must have been proud to finally have boards with PCI slots even though you had to configure everything manually in the BIOS
Have an ASUS PCI/VLB board were you set the PCI IRQ's by jumpers, 🤣
Reply 3 of 33, by Amigaz
Testec the same Matrox card on this motherboard + same CPU as I had on the MSI
http://stason.org/TULARC/pc/motherboards/G/GI … -REV-2-136.html
The board has UM8881F chipset
Just got a score of 7.5 in pcplayer bench
A Diamond Stealth 64 with VRAM gave 7.7 😜
On the MSI system it gave me a poor result of 6.7
Reply 4 of 33, by keropi
interesting stuff with this PCPBENCH:
AMD K6/II 450Mhz with an ALI based mobo with AGP:
Voodoo3/3000 AGP : 22.5
Diamond Stealth 3D 3000pro : 30.4 !!! (VirgeVX based)
wth? is the agp implementation of ALi so crap? I run some 3D games in win98 they are fine... and AFAIR I have tried a pci voodoo3 and it was crap in win98se , I think I tried Unreal in glide mode...
Reply 5 of 33, by Amigaz
keropi wrote:
interesting stuff with this PCPBENCH: AMD K6/II 450Mhz with an ALI based mobo with AGP: Voodoo3/3000 AGP : 22.5 Diamond Stealth […]
Ahhh...finally someone who hooks on to this thread and does some testing 😁
Amigo, maybe it's like the early PCI motherbords...the AGP implementation might be crap
Tried another AGP card?
Reply 6 of 33, by keropi
nope, not yet
I have a virge GX2, will try it now 😀
Reply 7 of 33, by keropi
damn, although AGP key is correct, the mobo won't boot with the GX2 card... and now it will not boot with a PCI vga, not even a voodoo3/pci or the same Stealth3000 ... it will only boot with the AGP/voodoo3 now... WTF!?!!!?!?
Reply 8 of 33, by GL1zdA
Check the BIOS for 'Init Display First' setting - it sometimes will mess things up. If it won't work, try to reset the bios settings (clear CMOS).
getquake.gif | InfoWorld/PC Magazine Indices
Reply 9 of 33, by keropi
OK progress
I noticed PCI cards default to normal 640x68x8bit modes, where ALL AGP ones default to 640x68x8bit LFB modes...
So I disabled Linear Frame Buffer with the /nolinear switch.
Voodoo3/3000 AGP : 46 !!!
Virge GX2 AGP : 42
edit: I suspect that SVGA games, like Shadow Warrior, Blood etc that have VESA2.0 modes result to this default LFB modes for AGP cards... How can I disable this for a voodoo3?
Reply 11 of 33, by keropi
is the version of NOLFB found here OK?
http://www.advsys.net/ken/build.htm
Reply 12 of 33, by 5u3
@Amigaz: The ALI M1429G is indeed one of the older PCI chipsets (and most certainly the PCI bus is bridged to the VLB), so the good performance is somewhat surprising. I'm wondering if the later M1439 and M1487 are even faster.
@keropi: The AGP implementation in AladdinV is a bit wobbly, but that doesn't affect DOS VBE modes that much.
Also, LFB modes should be faster than banked modes, not the other way around. Looks like some chipset features didn't get enabled by the BIOS...
BTW, my scores for the K6 system are a bit outdated since I forgot to enable write combining on the CPU. Here are my new K6-3+ scores:
AMD K6-3+, Asus P5A, Voodoo5 5500
      MHz | PCPBench score LFB (noLFB)
66x2 133 | 25.1 (20.8)
66x4 266 | 45.6 (35.9)
66x5 333 | 53.9 (42.6)
100x4 400 | 67.9 (53.5)
100x5 500 | 80.7 (63.9)
And more scores coming up: When sorting through some old stuff I found an AMD 5x86! 😁
Of course I had to try it out on my 486 board.
AMD 5x86, Asus PVI-486SP3, S3 Trio64V+
25x3 75 | 5.7 (5.1)
25x4 100 | 6.5 (6.0)
33x3 100 | 7.6 (6.9)
33x4 133 | 8.7 (8.0)
40x3 120 | 9.2 (8.3)
40x4 160 | 10.5 (9.6)
Meh. The weak FPU is really holding it back. 160 MHz and no chance for a big score 🤣
Reply 14 of 33, by keropi
OK, here are the 2 BIOS screens I think are relevant:
I have changed
Primary Frame Buffer to ALL
Data Merge to ENABLE
and IO recovery time to 0us
now pcpbench is 45.3 for LFB and 46 for normal... any ideas?
Reply 15 of 33, by Amigaz
Ok, tested pc player on my K6 rig.
Using a Geforce FX5200 AGP
Got lousy 33.2 but with the /nolinear I got a whoppin' 54.4 😁
Reply 17 of 33, by Amigaz
5u3 wrote:
@Amigaz: The ALI M1429G is indeed one of the older PCI chipsets (and most certainly the PCI bus is bridged to the VLB), so the g […]
25x3 75 | 5.7 (5.1)
Actually have a board with that chipset, another MSI board...4143 instead of 4134 which the VLB/PCI model is
Sadly the board seem to be dead..haven't completely given up on it though..still some more CPU models + memory combinations to try etc
6fcfe813614776.gif e5b2d913614778.gif free image host
Seems that this is the last model the used the ALi chipset on...Swaaye has the model that came after and it's equipped with the SiS 496/497 chipset
Reply 18 of 33, by 5u3
keropi wrote:
I have changed Primary Frame Buffer to ALL Data Merge to ENABLE and IO recovery time to 0us […]
I have changed
Yeah, that's definitely better than the 22.5 FPS you posted earlier.
Now try one of these K6 write-combining/MTRR utilities and check if it makes a difference. I've attached a DOS utility called MXK6OPT.
    MXK6OPT.ZIP
    8.91 KiB
    720 downloads
    Utility to set CXT core K6 MTRRs and enable write combining
Reply 19 of 33, by keropi
will try it 5u3 ! Thanks!
I wonder why there is no BIOS setting for that thing!
